Forums47
Topics113,308
Posts898,449
Members41,589
Most Online940 Apr 5th, 2017
Re: 1952 Suburban Update / MNSmith
[Re: MNSmith]
#1267150
Sun May 27 2018 01:33 AM
OP
So Cal
[Re: MNSmith]
#1268430
Fri Jun 08 2018 04:10 AM
OP
So Cal
[Re: MNSmith]
#1268454
Fri Jun 08 2018 02:57 PM
Mark, your posting work faster than I can read and keep up with it. You are busier than a cat on a hot tin roof!. Way to go. Glad to see someone is getting something done! You do good work.
[Re: MNSmith]
#1268471
Fri Jun 08 2018 06:29 PM
OP
So Cal
Hehe! I thought I slowed down a bunch this last month!
[Re: MNSmith]
#1268945
Wed Jun 13 2018 03:56 AM
OP
So Cal
The AC job has turned in to a big plumbing job. Work continues.
[Re: MNSmith]
#1269011
Wed Jun 13 2018 09:56 PM
...... I got it one piece at a time........JCash!!
[Re: MNSmith]
#1270512
Thu Jun 28 2018 04:24 AM
OP
So Cal
[Re: MNSmith]
#1271156
Wed Jul 04 2018 04:06 AM
OP
So Cal
AC done. Oh so nice. Time to turn my attention to exhaust!
[Re: MNSmith]
#1274831
Fri Aug 03 2018 03:36 AM
OP
So Cal
Just been cruising, enjoying my AC on these triple digit days. Still need to do exhaust. Looks like the speedo drive gear popped off the trans output shaft. Gotta fix that again. Did something dumb and found me a Model A Roadster to play with.
[Re: MNSmith]
#1275972
Sun Aug 12 2018 04:52 PM
OP
So Cal
Okay. The issue. When I started seriously building this thing in 2012, I threw on some quickie turbo mufflers so the neighbors wouldn't complain and the police wouldn't come down on me for "noise" issues. It was still on the loud side but use-able. Something I need to add to my to-do list, is pull the heads and reseal the valve stems. Evidence is all the soot that was gathering on the under side. But the thing that really bothered me was that the passenger side exhaust was dumping on the fuel tank, warming my gas. So, time to get serious about rerouting my exhaust. I used 2 1/2" pipe because that is what I originally used to gather at the headers. Plus that was stock '86 Corvette (my motor.) I brought to passenger side over to the drivers side, to help keep the heat away from the fuel tank, and went in to a 2 in, out 1 muffler. Similar to what is on my 1998 C3500. Unlike my C3500, which is 2 3/4" out, the out pipe here is 3". Two 45* and one 90* got me up and over the axle. I went straight out the back for now. The chrome tip hasn't shipped to me yet. When it does, I will also get a 90* and turn that pipe to go out the drivers side. Maybe the passenger side. I'll have to stare at it a while to decide. Either way, I can't burn anyone's knees or shins with it coming out the back like that. Results? I wasn't even sure the thing was running when I started it. Night and day difference. Unfortunately, now I can hear how bad the radio reception is and all kinds of new squeaks and noises I need to fix. It's going to take some getting used to, all this quiet! http://www.bunchobikes.com/1952suburban469.jpghttp://www.bunchobikes.com/1952suburban470.jpghttp://www.bunchobikes.com/1952suburban471.jpghttp://www.bunchobikes.com/1952suburban472.jpghttp://www.bunchobikes.com/1952suburban473.jpghttp://www.bunchobikes.com/1952suburban474.jpghttp://www.bunchobikes.com/1952suburban475.jpghttp://www.bunchobikes.com/1952suburban476.jpghttp://www.bunchobikes.com/1952suburban477.jpghttp://www.bunchobikes.com/1952suburban478.jpghttp://www.bunchobikes.com/1952suburban479.jpghttp://www.bunchobikes.com/1952suburban480.jpg http://www.bunchobikes.com/1952suburban481.jpg
