The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
18 members (ASU, 66flea, CJD, 51Gib, 59 fleet, Bill Trotter), 121 guests, and 2 robots.
Forums50
Topics120,472
Posts965,639
Members43,681
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Wheel seal for roller bearings
#826977 Fri Feb 17 2012 12:22 AM
Well, I got my inner rollers for my 3/4 ton today. I waited on getting a seal, so I could match them to the bearing. (Timken lists 2 different seals anyway, depending on the bearing you use.)
Does the seal ride on the spindle or the bearing spacer?
Anyone have a part number?
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
Re: Wheel seal for roller bearings
Whitedog #827003 Fri Feb 17 2012 01:31 AM
3B Offline
Hy Whitedog, could you tell us what year 3/4 ton you're asking about, and seeing as how you wonder if the seal rides on the bearing maybe the bearing number as well.
3B #827076 Fri Feb 17 2012 04:54 AM
His pictures are of a 1954.
1941 G506
More
1946 3800
Pic
More
1946 3600
Pic
More
1924 Ford Model T Fordor
641Workmaster #827389 Sat Feb 18 2012 05:39 AM
My original concern was with the thickness of the seal and the new bearing. Upon inspection it doesn't really seem to be a problem. I actually have a new problem though. The old felt seal, absolutely won't fit over the new bearing. The inner sleeve has a slighty larger outer diameter than the old one.
Timken has 2 listings for use with a B46 style bearing; #40973s with an i.d. of 2.093 and a #5756 with an i.d. of 2.062.
I'm going to have to research it more, but I believe I'm going to have to find a seal with a rubber inner lip and not a felt type seal.
"The Fake Truck"
Whitedog #839640 Thu Mar 29 2012 03:35 PM
Whitedog,
I have 2 sets of the 1-ton roller bearings, one for each of the two projects I have going.
I, like you, found that the o.d. of the inner race is larger than the original bearings. In addition, the set of bearings I purchased within the last year, don't even have a machined surface on the o.d. of the race. The set purchased about 4 years ago do have the machined surface.
I've measured everything and came up with the following results.
Ball (original) bearing -> race o.d. 2.093 (ground finish)
Roller bearing set # 1 -> race o.d. 2.153 (ground finish)
Roller bearing set # 2 -> race o.d. 2.157 (rough surface)
Both of these roller bearing sets are manufactured by MBS bearing in Japan who seems to have a good reputation. MBS Bearings, Japan I think they are the only ones producing these bearings.
I found a table of seal clearance guidelines and for anything under a 4" shaft, the clearance was +/- .030". There is clearly a problem with the o.d. of the bearing race.
The bearings with the rough surface are simply unusable. Seal manufacturers are very clear on what is a smooth enough surface. i.e. smooth with no tool marks
I may be able to find a seal with a 2-1/8 (2.125) shaft diameter specification that would work for the bearings with the finished o.d. surface.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'54 Chevy 6400 2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
No Room Left in Shop
OlBlue #839650 Thu Mar 29 2012 04:55 PM
How ironic this is. I have my inner bearing and vernier caliper in front of me as we speak. I was literally scouring through the Timken catalogs. I just came up with seal # 476535.
2.125 shaft
3.154 OD
.375 Width
Rock Auto has them for $10.63
I already have the 40973s seal, it seems like it'll work. If not I'll get the other.
I also came up with a Timken brand bearing that may be interchangable. It'll require a 9/32 thrust bushing behind it though. Right now it looks to be about 1/2 the price as the MBS. I'll have to see what the bushing will cost though. It may not be economical.
Chris
"The Fake Truck"
Whitedog #839661 Thu Mar 29 2012 05:50 PM
Following your lead I found another couple that may work in the Timken catalog.
55X80X8 & 55X80X8V
Different seal material & slightly different seal design between the two.
Maybe not so far up the creek after all.
'38 Chevy 1-1/2 ton
'49 Chevy 1/2 ton
'55.2 GMC 3/4 ton
'56 GMC 1-ton
OlBlue #839680 Thu Mar 29 2012 07:08 PM
That Timken site is awesome! There's literally everything you need there to cross over a bearing.
For a tapered outer wheel bearing I have a 1280/1220 combo. The dimensions are identical the b45 outer ball bearing.
For the inner b46 I get:
27880/27820 and 27881/27820 combo. Like I said before, all you need is a 9/32" thick 2" ODx 1.5 ID thrust bushing to make them work.
These bearings are already in production too. The 27880 was used on 46-52 Fords and 87-91 Ferrari's. The 277881 was used by IH from 55-72.
It's too bad I already bought the MBS.
Chris
"The Fake Truck"
Whitedog #840067 Sat Mar 31 2012 04:07 AM
You can let the seal ride on the thrust bushing, that's how it's done on MGBs the inner and outer timkin with a bushing is how they do it.
The seal runs on the spacer
Seems like you guys have done the leg work for me
Moderated by  Grigg
