The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (DJMTruck, DennisM, chaz71, 95Z28A4, 66flea, dirtball, 1 invisible), 155 guests, and 3 robots.
Forums50
Topics121,048
Posts970,425
Members43,831
Most Online1,229
Jan 21st, 2020
Image Posting Policy
1955 - 235 Fuel Pump
#815680 Thu Jan 12 2012 06:07 AM
Is it common for a manual pump to bleed off after sitting a day. I have one that empties the fuel filter but have no external leakage and no signs of it going in the crankcase. It does pump it right back up when cranking. Just wondering?
Re: 1955 - 235 Fuel Pump
Gmans 46 #815724 Thu Jan 12 2012 03:07 PM
It should hold the fuel from draining back.
Gmans 46 #815758 Thu Jan 12 2012 05:06 PM
If you have any rubber hose sections in your fuel supply line, pinch it closed with vice grips, after running the engine, and see if it starts right up after a day or two.
Stovebolts are good for the heart
truckcamper43 #815777 Thu Jan 12 2012 06:14 PM
Ok, I'll give it a try, it does have a rubber hose in several places with a poly tank. I was wondering where it was going like being drawn back to tank by a siphon effect or what. Like most projects you get sometimes the PO may not have done things quite up to par.
Gmans 46 #816472 Sun Jan 15 2012 02:45 PM
I have had little pieces of crud get stuck in the valves and cause problems, it is apparent the valves are leaking due to something
Moderated by  Woogeroo
