The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
23 members (carbking, 5 Window 9434, Cozsum, 7Jiggy, 4 invisible), 127 guests, and 3 robots.
Forums47
Topics117,784
Posts942,437
Members43,042
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: Yet another 6 volt coil question-flame thrower II
Hotrod Lincoln #805774 Sun Dec 11 2011 06:02 PM
I agree with all that Kurt. Unless youíre running an engine with high compression and at
High rpm there really isn't a need for a high voltage output coil. It takes a given amount of
time for the field to build to saturation and as the rpm increase there is a point where there
simply isnít enough time for the field to build and the coil looses itís punch. Thatís were
a high voltage coil finds itís place. The stock coil is quite adequate for a stock engine
operating with in its factory power band.
DG
Denny Graham #806331 Tue Dec 13 2011 12:09 PM
Thanks guys, good input. Here is the response from pertronix TECHNICAL staff after asking them if this is the proper coil for my 49 chevy truck with 6 volt and still running points:
Kurt,
All of our coil are 12V and will work on 6V system when using the correct
coil and Ignitor setup.
Are you using our Ignitor and how many cylinders is your engine?
NOTE: MAKE SURE THE CORRECT COIL IS INSTALLED OR YOU WILL DAMAGE THE
IGNITOR.
Carl Alcocer
Technical Support
PerTronix Performance Products
440 E. Arrow Hwy
San Dimas, CA. 91773
Kurt_stovebolt #806357 Tue Dec 13 2011 03:01 PM
ace skiver
Kurt,
It looks like Pertronix has confirmed to you what they told me.
It also confirms why that 12v/6v Pertronix coil with 6v Ignitor has been working fine for me for over 10 years.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Page 2 of 2 1 2
Moderated by  Rusty Rod
