The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (9% grade, Harold46, JiMerit Boltr#43, Raineman, Pete AK, 1 invisible), 251 guests, and 3 robots.
Forums50
Topics120,033
Posts961,335
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: 12 Volt Alternator Issues.
Hotrod Lincoln #800163 Wed Nov 23 2011 02:56 AM
No the number one wire I was referring to was the one designated number one in the wire harness instructions.
Thanks, Jerry. I'll get a new one and go from there.
Trombones Totem Poles And Old Trucks!
1946GMCDAN #800551 Thu Nov 24 2011 05:01 AM
ALL RIGHT!! Got it in today and all is well with the charging. Bad alternator. Thanks for helping me through this. Now on to resolve the gas gage issue.
1946GMCDAN #800556 Thu Nov 24 2011 05:21 AM
Boltergeist
"I love it when a plan comes together!" Good show!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
1946GMCDAN #802571 Thu Dec 01 2011 04:02 PM
This is pretty simple.....The yellow wire goes to the (+) terminal on the ignition coil and is known as the exciter wire. It is the one that tells the alternator to go to work when you turn on the ignition key. The short red one needs to go to the 10/32 BATT stud on the back of the alternator and that is for the internal regulator to tell it what to do. Finally you should have a 10 gauge wire going from the BATT stud on the back of the alternator up thru the amp gauge then over to the starter solenoid where the battery cable connects. That will deliver the output from the alternator to the battery to keep it charged up....and you will live happily ever after. Randy
1946GMCDAN #802575 Thu Dec 01 2011 04:10 PM
Ok here goes...The yellow wire should connect to the (+) terminal on the ignition coil and has the job of turning on the alternator when you turn on the ignition key to make it begin to charge. The short red wire in the plastic plug connects to the 10/32 stud on the back of the alternator marked BATT and is for the internal regulator so it knows what to do. Finally you should have a 10 gauge wire from the 10/32 stud on the back of the alternator that runs up thru the amp gauge in the dash then on over to the battery post on the starter solenoid. that is how the output from the alternator get to the battery. Do this any you will live happily ever after.....Randy
Page 2 of 2 1 2
Moderated by  Rusty Rod
