The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (Ga92009, 9% grade, Texas Hussy, Harold46, JiMerit Boltr#43, Raineman), 244 guests, and 3 robots.
Forums50
Topics120,033
Posts961,335
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
6V-12V Is this Right?
#789951 Tue Oct 18 2011 09:44 PM
EricJ Offline OP
I found a site that suggested some parts to use for this conversion. Has anyone looked at this and have some opinion on its level of correctness?
http://www.how-to-build-hotrods.com/6v-to-12v.html
I would like to try the conversion that does not require the ballast resistor. I understand the lights and gauge portion of the change over, I am still fuzzy on the ignition system.
Re: 6V-12V Is this Right?
EricJ #790072 Wed Oct 19 2011 03:49 AM
If your using a points type distributor you can use an internal resister coil and omit the ballast resister but most are going to electronic for better starting and running. Pertronics has an electronic conversion kit that lets you keep you old distributor or many use the GM HEI if your engine is a GM. On an HEI be sure to run a 12g wire from the switch to the dizzy. Many use the factory 16g wire and wonder why modules have a short life. Both the HEI and Pertronics have a proven record over many years.
Evan
coilover #790395 Thu Oct 20 2011 01:48 AM
EricJ Offline OP
Thanks Evan,
I didn't realize people were upgrading their ignition systems. I was planning on using the old system while I worked on other stuff.
That is something to keep in mind for the future.
Eric
EricJ #790592 Thu Oct 20 2011 05:25 PM
You can use your stock ignition and get along fine. Use a NAPA coil IC64 that has the internal ballast resistor,and get a Runtz for your fuel gauge and a HD heater resister from Fifth Avenue and life should be pretty good. You do not need to change anything inside of the distributor....I wrote a book many years ago called "The official 6/12 Conversion Guide" which would help you. It explains what you need to do and why. It is $10.00 post paid. thanks Randy
EricJ #790593 Thu Oct 20 2011 05:28 PM
As for the correctness of that 6/12 conversion link it looks to be about 50 percent accurate. Most of it is information that was around during the 1960's and early 70's and is no longer current....thanks Randy
fifthave #790622 Thu Oct 20 2011 07:22 PM
EricJ Offline OP
Thanks Randy,
The coil with the internal resistor is all I need for now I think. The original gas tank and fuel level sender are no good anyway so I'm planning on getting the motor started out of a can after I get the ignition wired.
Eric
Moderated by  Rusty Rod
