The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (David C., glenns towing, DennisM, EdPruss, 3B, FootStomper, 1 invisible), 285 guests, and 3 spiders.
Forums47
Topics115,008
Posts912,471
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Another 6v electrical boost question! #784205
Tue Sep 27 2011 10:29 PM
fonz8261  Offline OP
Michigan
My '48 Chevy 1/2 ton p.u. is still a 6v system. I am using an original Guide turn signal switch and front/rear lamps--no emergency flash feature. I have installed a vintage 6v amber service lamp on the truck, which can act as an emergency flasher. Is there an electrical component that can provide me with 4 amps or thereabouts so that I may be able to have this amber service light flash faster and/or brighter?
Thanks for any insight on problem-solving this for me (and others).
Re: Another 6v electrical boost question! [Re: fonz8261] #784249
Wed Sep 28 2011 01:16 AM
di1953gmc  Offline
Kansas City, Missouri
This is academically simple but realistically more difficult.
Ohm's law states that, V = IR
where:
V = voltage
I = current
R = resistance
Two ways to increase the current are:
1. Increase the voltage while holding the resistance constant... By adding a battery or power source.
and
2. Decreasing the resistance while holding the voltage constant... By increasing the wire size (significantly) and all connections.
I don't know of a better way.
Dale
When I die, I want to go peacefully like my Grandfather did, in his sleep -- not screaming, like the passengers in his car.
-Unknown-
Re: Another 6v electrical boost question! [Re: di1953gmc] #784389
Wed Sep 28 2011 12:59 PM
beltfed  Offline
Knoxville, TN
There are several ways to go about this. You can add another flasher "can" wired thru a switch to activate your light as a flasher. Other options are to use an electronic flasher unit with allows you to vary aspects of the flash. As for brightness, change bulbs, use a voltage doubler, go the led path. Then again, you don't even need the additional light if you hsve brake/tail/turn lights. The above flasher "can" can be wired into existing lights.
Re: Another 6v electrical boost question! [Re: beltfed] #784412
Wed Sep 28 2011 02:29 PM
Tiny  Offline
Global Mod
South Central Kansas
There are step-ups that boost the voltage to 12v but I don't know the amperage capability. There's a seller on ebay that told me he'd build me whatever I needed but I don't have his ebay name any longer.
Re: Another 6v electrical boost question! [Re: Tiny] #784430
Wed Sep 28 2011 03:40 PM
BillyDon  Offline
Ohio
I just bought a voltage booster from Jim Carter. According to the owner's manual, "When used in a 6 volt system, it can continuously supply more than 3.5 amps with the engine off, and about 5 amps with the engine running at a fast idle."
My dad always told me, "Don't force it, get a bigger hammer".
Re: Another 6v electrical boost question! [Re: BillyDon] #784476
Wed Sep 28 2011 06:55 PM
di1953gmc  Offline
fonz,
Do you want a voltage booster or an amperage booster? One is easy, the other...not so much.
Dale
-Unknown-
Re: Another 6v electrical boost question! [Re: di1953gmc] #784586
Thu Sep 29 2011 02:18 AM
fonz8261  Offline OP
Michigan
Voltage--1st
Amperage--2nd
Re: Another 6v electrical boost question! [Re: fonz8261] #784772
Thu Sep 29 2011 08:58 PM
di1953gmc  Offline
Well, after re-reading your post I think I may have an answer.
First, a little background:
The speed of a conventional mechanical flasher is dependent on the amount of current flowing through the circuit. Thus, if a bulb burns out (not drawing any current), the flasher slows or quits all together. Alternatively, if you replace the bulb with one that pulls more current (which will be brighter... the second half of your request) it will flash faster.
So, I believe if you replace your bulb with a special one, perhaps a halogen or super bright led one, it may solve both issues at once... faster and brighter.
The only down side to this idea is it may prematurely burn out your existing flasher and you may need to go to a heavy duty one.
Hope this helps,
Dale
PS... Several of the posts above have suggested good ways to boost the voltage, as for an amperage booster, first you need to know if your existing generator is at it's maximum capacity.
-Unknown-
Re: Another 6v electrical boost question! [Re: di1953gmc] #784780
Thu Sep 29 2011 09:33 PM
tclederman  Offline
Boltergeist
Jarvisburg, NC
"Thus, if a bulb burns out (not drawing any current), the flasher slows or quits all together.
Dale,
I know nothing about flashers but all the flashers on my vehicles (6v or 12v) flash faster when a bulb burns out? That is usually how I find out that I have a bad bulb.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 50 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 14 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: Another 6v electrical boost question! [Re: tclederman] #784782
Thu Sep 29 2011 09:41 PM
Tiny  Offline
Global Mod
That's what I was thinking Tim. That's how mine have always acted when a bulb dies.
Page 1 of 2 1 2
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
