The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (fixite7, Charles in CA, lumbersawyer, Johnny N, Cosmo, Hotrod Lincoln), 205 guests, and 3 robots.
Forums50
Topics122,132
Posts979,693
Members44,158
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Bed Kit Help for 53 3100
#777593 Sat Sep 03 2011 03:47 AM
I'm installing a bed kit with predrilled holes in my 53 chevy 1/2 ton. Before I install the boards, I have a question about the cross sills. I mounted the front sill using 2 blocks (no rubber pads). The second sill will be floating and not attached to the frame. The 3rd sill is mounted to the frame behind the rear axle using only blocks (no pads). The rear sill has only a rubber pad between the sill and the frame. Is this correct and will this get me the correct spacing between the sills and the angle strips where my boards will fit under?
My second question is the boards themselves. I have an 8 board kit. The manufacturer says the 4 1/4 boards go under the angle strips with the 2 drilled holes placed close to the front sill vs the rear sill. This doesn't seem right as the holes match up better if I place the holes down by the rear sill. Does anyone know which is correct? Thanks.
1953 3100 Chevy 5 window
1971 Chevelle SS
Re: Bed Kit Help for 53 3100
1953Chevy #777890 Sun Sep 04 2011 12:56 AM
Go to these for help. Factory fit is a pad under every block and the end sill metal blocks. You need six rubber pads for a 3100.
http://www.speedprint.com/deves50/bedwood.php
http://www.mar-k.com/bed_parts_installation.html
Brad Allen #778028 Sun Sep 04 2011 05:57 PM
Thanks Brad, the blocks I bought only had 2 pads with them. It makes sense so to prevent squeaking between the wood and the frame.
1971 Chevelle SS
1953Chevy #778096 Mon Sep 05 2011 12:03 AM
Probably purchased from ClassicParts which refuses to believe numerous people who have tried to tell them the correct kit make-up.
Brad Allen #778437 Tue Sep 06 2011 02:50 AM
yep Brad, that's correct. I was finally able to install the bed kit this weekend. It came out great but I didn't put the pads under the blocks. Not something I want to re-do after all the time I spent.
1971 Chevelle SS
1953Chevy #778732 Wed Sep 07 2011 03:34 AM
ace skiver
Brad,
I got that 47-53 bed block/pad kit from Classic Parts: 4 blocks and two pads. My problem is that I ordered a 54/55 kit that was supposed to be 8 pads and no blocks.
I guess I should be happy because I had ordered a lot of parts (to get free shipping). They also sent me two different sized front axle bumpers. At least I will not have to argue that one is the wrong size (they can't both be correct).
http://www.classicparts.com/1947-53-Bed-Mounting-Blocks-Pads-Shortbed/productinfo/13-511/
http://www.classicparts.com/1954-87-Bed-Mounting-Pad-Shortbed/productinfo/13-555/
Jim Carter has the right kit:
http://www.oldchevytrucks.com/cart/product.asp?prodid=BP137&i=9515|||
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #778804 Wed Sep 07 2011 01:40 PM
Tim,
For the most part I like their stuff but rarely do I get my order that is not short or has extra stuff in it like you describe. I spent some time on the phone with the parts manager and was told their kit was correct. I then sent him links to other catalog sites with correct kits like Jim Carter all of which came to nothing.
Brad Allen #778904 Wed Sep 07 2011 08:30 PM
Boltergeist
what gives with those guys. I had a problem with one of their cowl panels and even showed them THEIR own two pieces did not match up...not even close! After offering up a great solouticn (a new NOS piece to copy) I was politely told they had no problem with them for 20 years. I posted the conversation here that I had with them including their personal reply but it was deleted for "vendor bashing".
Hey, facts are facts. I don't know if they ever corrected the problem or not. I doubt it.
We have a right to inform our buddies if ANY piece is crap from ANY vendor. That does not say the vendors do not have other good stuff or good service. It just shows their un-willingness to make or correct ONE product that is a dud! ..... I better be quite!!
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.google.com/share/AF1...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
52 Chevy Panel [photos.app.goo.gl]
Achipmunk #779674 Sat Sep 10 2011 10:01 PM
Interesting posts regarding pads. On my 1949 half ton I have six blocks and four pads. The pads are at the front and rear sills. There was/is a small 12 page booklet entitled "Bed Restoration Manual" and it states that bed block pads are on the first and last sill. There is no mention of pads on the other sill which is bolted to the frame. That does not mean there are or there are not blocks at that location. I do not have pads on those blocks.
I am chasing a very elusive thump and rumble whenever I hit a good bump and wondered if my bed was the culprit. However I believe that with or without the pads as long as the blocks are bolted to the frame securely there should not be any thump - only squeak.
"Sedgewick"
1949 Chevy 1/2-Ton
1989 Caprice
Sedgewick #779694 Sun Sep 11 2011 12:17 AM
If you need help regarding the blocks and pads, we have a great set of instructions for you.
Look here: http://www.mar-k.com/bed_mounting_information.pdf
Hope this helps.
Page 1 of 3 1 2 3
