The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
9 members (captianworkbench, Johnny N, joe apple, JoeR, baldeagle, 1 invisible), 154 guests, and 3 robots.
Forums60
Topics124,697
Posts1,006,493
Members45,007
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Chevy 292 Vs. GMC 302
#76084 Mon Apr 09 2007 03:42 AM
Junior Member
I plan on doing an engine swap sometime in the future on my 47 2 ton and was wondering if anyone knew of some of the advantages or disadvantages of either engine. Which one was tougher or torquier. I know where I can get a Military GMC 302 rebuildable long block for 800. I've heard you can bore the 302 out to 4.125 with sbc pistons and stroke it out to 4.250 with mopar rods making it into a 341. I haven't heard much about boring or stroking a 292. If anyone has any information i would greatly appreciate it. Perhaps any ball park horsepower and torque figures or even dyno tests. I'm mainly looking for low-mid grunt and I don't want a v8.
Re: Chevy 292 Vs. GMC 302
#76085 Mon Apr 09 2007 05:12 AM
I don't have direct answers to the specific questions you ask, but I do have a couple of thoughts regarding the two motors.
First is that a GMC 302 is going to swap into your truck with very little modification since the configuration is the same as was used in the GMC versions of these trucks.
On the other hand, the 292 is a more recent design and likely easier and cheaper to buy parts for.
Comparing performance of modified motors is a bit more difficult and I don't feel qualified to do that...
Its true, I really don't do anything but browse the Internet looking for trouble...
Steve@OldSub.com . www.OldSub.com . www.MaxwellGarage.com . www.OldGasTowRigs.com
'55 1st GMC Suburban . '54 GMC 250 trailer puller project. '54 GMC 250 Hydra-Matic . '54 Chevy 3100 . '47 Chevy COE . and more...
#76086 Mon Apr 09 2007 10:56 AM
The main downside of the 302 will be the fact it was a fairly limited production engine when it was new, and parts availability hasn't improved over the years. On the plus side, it's going to look more original, and it will be close to a bolt-in swap.
The 292 is rugged, recent-manufacture, and at least some parts will interchange with the smallblock V-8 line, making repair parts much more affordable. You'll have to do a lot more adapting to make it fit your chassis, however.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
#76087 Mon Apr 09 2007 04:17 PM
Nothing exchanges with V8 except lifters, valves and valve springs.
You should ask Tony #107 your questions. He built a warmed up 302 for his '37. He doesn't post here that often anymore. You can probably find him hanging out with the other strictly GMC guys.
Old GMC Trucks
Look in their Discussion boards. Those guys would have an idea of what is available and where.
'67 GMC 3/4 292 4spd
#76088 Mon Apr 09 2007 04:31 PM
The 292 shares the bellhousing and flywheel with V-8's. You would probably have to find a crossmember from a TF/60's truck to match with the bellhousing.
Fred
#76089 Mon Apr 09 2007 05:24 PM
''The 292 is rugged, recent-manufacture, and at least some parts''
ANYWAY you cut the mustard
it's ALL EXPENSIVE....................................
As far as the ''COOL FACTOR''
.....................IT's ALL COOL
FIRST buy leo santucci's book on powering L6 motors. read it
learn to do a search on this bolt page about 292 vs 302's as there is LOTS of that info out here.
the search button is in the upper right corner.
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=2;t=009843#000000
the 302 is longer than any other L6, where as 194-292 are the same length.
more parts are avail for 292's. intake, exh manifolds, valve covers & tin-work, pistons /cams are more affordable
it all depends on what you want or how much time you want to spend sourcing vs driving.
there are lots of very good engines out there. at one time when and shortly after i got our little 3104, i knew we needed a new engine. re-building a 235 was 3-4 times the expense vs. what i was lucky enough to find my 292 completely rebuilt and ready to install. so that's a no brainer. the 292 won my vote. 250's rev a little higher than 292's and are a little faster. 292's have torque, you have a 2ton so consider a 292. there are many trade offs to building a reliable bolt.
it's your choice. differences are also made w/ a modern tranny and rear end gearing.
good hunting and luck.
my.02
Jim & Caroline
The highway is for gamblers
Better use your good sense."
Gooday
that's my 1ยข answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Lucinda Otter-Purr our 51-3104 bolt
http://s67.photobucket.com/albums/h298/1951otter/?start=all
Inliner #4655
Every Shaver
Now Can Snore
Six More Minutes
Than Before ...
Half A Pound for
Half a Dollar
Spread On Thin
Above the Collar
BURMA-SHAVE
#76090 Mon Apr 09 2007 05:42 PM
I just measured a GMC engine and a 292 Chevy that are sitting side by side in my garage, they are both almost exactly the same length from the back of the block to the end of the water pump shaft, both are 33" long. My 292 is stock bore but if you choose to bore it .060 it will be a 302. The 292 has 7 main bearings and the 302 GMC has 4 mains, so the lower end is stronger in the 292, the head of the 302 has nice ports and valves so it breathes good, but the 292 head can be easily modified to breathe better than the 302. Unless you get a 12 port head (read expensive and rare) for the GMC, the 292 with a little work will make a good bit more Horsepower than the 302. There is no substitute for cubic inches, so the 292 will always make more horses than a 250. My mildly modified 292 with head work, cam and headers with 3 Weber sidedraft carbs makes about 350 Horses, and is a great street engine. Destry, good luck with the '47, I know you will enjoy it whatever engine you use.
#76091 Mon Apr 09 2007 10:38 PM
I'd go with the 302 just for the "cool" factor. These are the engines that were blowing flathead Fords and 265 Chevies out of the water back in the day.
There are some mods that the military 302 will need. There is a great article on this at the OldGMCtrucks.com forums.
My TRUCKS website
#76092 Tue Apr 10 2007 12:16 AM
Destry,
Is your truck a chebby or a Jimmy? If it is a chebby I'd go with the 292. If it's a Jimmy I'd think about the 302 since it would be a bolt in swap. 302s are a little bit more spendy than a 292, but they definitely have the wow factor. Very few people outside this forum and others like it would even notice the difference between a 216, 235, 261, 228, 248, 270, 302, or a 292.
#76093 Tue Apr 10 2007 12:22 PM
Hello Richard!Come on over to the "other site"Chevys are welcome,lol. Yeah,I put a modified GMC 302 in my 37 Chevy pu to replace the modifed 261.It bolts in after you move the radiator foward and fab up a spacer for the front motor mount.
GMC's are somewhat expensive to modify,but not that much more than a 292 Chevy perhaps,which is a more pricey than a common V-8 unless ya shop carefully for bargins.
A modified GMC 302 that's streetable,headers,cam,forged higher compression pistons,more carb,makes about 240-260 HP and 340 lbs ft of torque with a mildly reworked head.The Chevy 292 is probably capable of more power for the same money spent as mentioned above.For instance, bearing sets for the GMC are expensive,specially for better bearings like the discontinued Clevite 77's or GM Morriane 400 bearing sets.
Impress the public? most don't know what there're looking at anyways.I've had guys look at the 302 in my 37,ya see headers,Holley 4 bbl,extra crankcase breathers and they ask "is that the stock flathead 6?
Anyways,the 302 looks old school under the hood and I like it..
Page 1 of 2 1 2
Moderated by  Woogeroo
