Come all who are near!
Southern Bolters Jamboree
this weekend
June 2-3
in
Tennessee
Details here
Still plays with trucks
Things are happening all over. Missing anything? Check in the The Side Lot and see.
Searching the Site
2023 Old Truck Calendars
Second one
Sweet-looking old Stovebolts
2023 Stovebolt Calendars
Check for details!
11 members (2-Ton, Hotrod Lincoln, 1953 Forever, 55shaker, blue67fleetside, 1 invisible), 221 guests, and 3 robots.
Forums64
Topics129,522
Posts1,068,117
Members46,944
Most Online1,229
Jan 21st, 2020
#758550 Wed Jun 29 2011 07:13 PM
Hi all you Stovebolters,
My question is: how many leafs may I remove "safely" to lower the frontend of my 49 3100 pickup and still have drive-ability? I already have the powersteering conversion and disc brakes up front. I installed a TCI rear spring conversion and 69 Camaro 10 bolt in the back, so 4-5 inches lower in the back.
Thanks for your help!
Wayne
Wayne,
I did the same thing you did and also put 15" wheels in place of the 16's and I removed 3 of the smallest leafs and installed spring sheets between each , new u bolts and center bolt. I wish I could go lower but the bumpstops are bout 1" from frame and new lowered gas shocks make the diffrence.
Good luck!
Mike
wayne,
on my 57 i am running just 3 of the original 6 leafs, with gas shocks, and it rides "decent". gotta watch out for the bigger bumps in the road since it will bottom out kind of easily, but the look, stance, is what i was after.
oh yea, im also running one of Sid's 3 inch dropped axles.
leonard
1957 Chevy 3100 1/2-Ton
Photobucket pictures
Taking leaves out of front springs seems to be a Mickey Mouse idea.There are good front ends on the market that will get you lowered and also have a nice comfortable ride and handling.I put an M2 front end in my 55 from TCI it works great.
yea, taking the leafs out is just a temporary solution for me, but it works decent.
i hope to one day do an IFS install like the mustang II, but dont know when i will have those funds available.
leonard
I'm sticking with my dropped axle and Mickey Mouse 3-leafs removed. Rides and handles great.
I don't trust a system that was basically designed for a Pinto or a Mustang II. Had one in a '59 truck and it was fine for 2 years. I came out one morning to drive it to work and the front end was completely collapsed, truck was sitting on the ground! I guess during the night the springs got together and decided they weren't going to support that kind of weight any more!!
I never trusted that dang frontend after that.
WOW.... no kidding.... maybe i will always stick with my mickey mouse drop too. LOL. that sounds scary for sure...
leonard
dropped axle, mustang II, or g body clip you can see my burb 4 inch dropped axle mono leafs, de-arc rear leafs
"THE CUT MASTER"
1949 SUBURBAN
292, t-5, disc brake rear end
In the Gallery [stovebolt.com]
1947 ON D FLOOR FLEETMASTER 350/350 mustang ii
1954 DELUXE CAB 250, t-5, chevelle clip
1954 CHEVY HARDTOP soon to have 250, 700 r4, mustang ii
View products here http://resurrectionauto.storenvy.com/
Resurrection Vintage Auto Parts [resurrectionvintageautoparts.webs.com view website here ]
