We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229 Jan 21st, 2020
 Door window channel "retainer" ? help
OP
I need help in finding the following part. It is the guide that holds the door window channel on the back of the door. Please see picture. I think I've seen them on a vendors site but can find now. One was broken when removed. Thank you for your help, Scott http://i740.photobucket.com/albums/xx49/49chevyia/IMG_1458.jpg
 Re: Door window channel "retainer" ? help
These channel guides are for 51-54 but you may find them here for your 49. I think the earlier models had window guidies that are wider. http://www.classicparts.com/Door-Rubber/products/4/also try JimCarter or American Classic
Nice truck. What side are you looking for?
Dennis -there is nothing stronger than the heart of a volunteer-
OP
I'm not completely sure. I think it is the driver's side. I'll have to look closer when I get back in town.
Thx for the kind words. It's almost done except for the interior overhead and the door windows. I quess it's time I put something in the gallery.
OP
looks like drivers side.
THX for everyone's help. Achipmunk - have a great weekend!
I could only find these guides used. Jim Carter said they were working on reproducing them but don't have them yet. The front rails are the opposite sides rear. Hence, the front driver side is the passenger sides rear. And vice versa.
They seem to rust out just above the block that is spot welded to the front of the door. And the drivers side seems to be the worst of the two to do this.
I hope this helps
OLTrucks
Unregistered
I know I would rather have a good used US made one then an asian made part, kinda goes for almost all parts.
