The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (Lightholder's Dad), 305 guests, and 3 spiders.
Forums48
Topics116,172
Posts923,798
Members42,360
Most Online940
Apr 5th, 2017
Image Posting Policy
Headers for 62 #748565 Fri May 20 2011 06:51 PM
beancan Offline OP
Does anybody know what headers will work on a 62 C10 with a 350 and 700R4. Hedman rep suggested the model 68390 but parts guy at scoggin dickey says if i buy and try to put them on and they dont work i may have a hard time getting hedman to take them back.
Re: Headers for 62 [Re: beancan] #748667 Sat May 21 2011 05:02 AM
Brad54 Offline
The V8 trucks came with rams-horn manifolds, and had the exhaust pipes routed up to them. I like to keep things simple:
I'd use reproduction 2.5-inch Rams Horn manifolds, the new Speedway rams horn manifolds, a set of shorty headers, or if you've got the front saddle-mount and no side mounts, I'd maybe go with some of the reproduction Fenton Tri-Y cast iron headers.
Unless you feel you NEED full-length headers. If that's the case... then I got nuthin.
-Brad
SOUTHERN FALL GABfest
October 6 ~ Commerce, Georgia
Details here!
Never Pee on an Electric Fence.
Re: Headers for 62 [Re: Brad54] #748672 Sat May 21 2011 05:26 AM
beancan Offline OP
thanks for the info I will probably go with the ramhorns they would be easier to mate up to with exhaust pipes. also i will be putting on ac at some point since i want my wife to go with me in the Texas heat.Ha Ha I got a 62 cause im a 62 model myself and i am having a lot of fun with it. when i get back together i will try to post a pic. thanks again.
Re: Headers for 62 [Re: beancan] #748706 Sat May 21 2011 01:27 PM
gazim Offline
The rams horn work out the best, No leaking and efficent.
Re: Headers for 62 [Re: gazim] #748730 Sat May 21 2011 04:01 PM
Brad54 Offline
Muscle car resto houses carry 2.5-inch Rans horns, as do Dorman dealers.
The 2.5-inchers were the factory hi-perf models; others were 2.0 or even smaller.
-Brad
Details here!
Re: Headers for 62 [Re: Brad54] #750448 Sun May 29 2011 03:41 PM
Longbed61 Offline
I had the c10 headmans on my 61. They worked ok after I hammered one tube, notched the bell housing cross member (which you already cut out or your auto trans would not fit) and relocated the brake lines for driver front. If I were to do it again, I would have used the 327 vette ramhorns like mentioned above. Thought I would chime in, just incase you had any remaining doubts about the ramhorns.
Re: Headers for 62 [Re: Longbed61] #751425 Thu Jun 02 2011 04:26 AM
Slick Willy Offline
Anybody use the Sanderson shorties on their early 60's truck? I had them on a 305 sbc in my '56 Chevy and they cleared just fine. But they may not work out on the later models...
Moderated by  Hambone, sixtyfive c-10
Powered by UBB.threads™ PHP Forum Software 7.7.3
