The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (55 SHAKER, Chasz, coilover, Cosmo, 2 invisible), 315 guests, and 3 spiders.
Forums47
Topics116,133
Posts923,468
Members42,352
Most Online940
Apr 5th, 2017
Image Posting Policy
bed wood options #740325 Mon Apr 18 2011 05:51 PM
Hawkguy54 Offline OP
What if one were to use a single piece of exterior grade oak plywood as a bed with strips bolted through. What are the pitfalls of this idea snd how should the wood be finished?
Re: bed wood options [Re: Hawkguy54] #740406 Mon Apr 18 2011 10:35 PM
bowtiefan Offline
Thats what I did, cept I used cabinet grade since I have alot of that on hand. Sealed it with epoxy (also have lots on hand), and bolted SS strips down on it. Did not rout grooves...wanted the strips above the wood for protection.
Re: bed wood options [Re: bowtiefan] #740540 Tue Apr 19 2011 05:33 AM
Britcon Offline
Toughest thing would be sealing the edges and holes well enuf to prevent water getting in and swelling / warping plywood. Also with oak ply, you don't get the grain variation you see with individual planks. Veneers are pretty thin surface. Make your own planks. I bought 1 x 6 & 1 x 8 dressed Oak at a wood worker supply place for around $ 125.00. Grooved the edges with a table saw.
Re: bed wood options [Re: Britcon] #740546 Tue Apr 19 2011 05:54 AM
1958GMCnut Offline
delamination of plywood is a certainty.....
GMC: Get More Cash...
1958 GMC
My Webshots photos
Re: bed wood options [Re: 1958GMCnut] #741275 Thu Apr 21 2011 04:07 PM
jomichael Offline
What are your reasons for wanting to go that direction? Durability? Beauty? Ease of installation? What is your goal?
Re: bed wood options [Re: jomichael] #741288 Thu Apr 21 2011 04:51 PM
Builder Offline
If you are trying to do this with as little work as possible, just throw the plywood over the top of what is there. If you have to take it all apart to put the boards in, and you are just using the truck for a driver or a "not for show", just get some 1 by's and cut them to fit. I believe the instructions can be found here at the bolt or at Mar-K (look in the upper left of this page). I just used some good construction lumber and used a good UV resistant deck finish on mine. Replacing the boards as they were from the factory will eliminate a ton of squeaks and rattles too. http://www.mar-k.com/bedwooddimensions.pdf
Re: bed wood options [Re: Builder] #742615 Tue Apr 26 2011 03:05 PM
gazim Offline
Mine is done that way and 4 years old(I keep it garaged)
still looks great. I did seal it top,botom and sides. Ieven inset the strips as normal on a table saw. Dado blade.
Powered by UBB.threads™ PHP Forum Software 7.7.3
