The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (delky, ClassicsR4Me, Denny Graham, 51Gib, 4 invisible), 168 guests, and 5 spiders.
Forums48
Topics117,457
Posts938,961
Members42,863
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 15 of 16 1 2 13 14 15 16
Re: Tango's '46 Shorty Bus [Re: Tango] #1229862 Sun Aug 13 2017 02:35 PM
Tango Offline OP
Thanks Chip --- But I don't know how good a teacher I'd make since I'm learnin' all this as I go myself. If I could pass anything on to kids today, it would be an unbounded sense of curiosity combined with the willingness to do the work necessary to figure things out. Easy answers aren't nearly as much fun.
1946 1.5-Ton Chevy Shorty Bus
More pix on Flickr
All my best --- Tango
Re: Tango's '46 Shorty Bus [Re: Tango] #1231018 Sun Aug 20 2017 03:23 AM
EdPruss Offline
Tango,
Did you ever get your air cleaner location worked out?
Ed
Re: Updated Pix of '46... [Re: Tango] #1231429 Tue Aug 22 2017 03:56 PM
GreggE Offline
That thing is Sweeeeeeet. Great Job
Re: Updated Pix of '46... [Re: Tango] #1232011 Fri Aug 25 2017 08:48 PM
Tango Offline OP
Thanks Gregg. Just saw that beauty you put together. Absolutely perfect for what you are doing. Sweeeet!
Ed --- Still putzing around with the air cleaner thing. Have not found a unit that will adapt well. Saw a home built over on a 4x4 forum made out of cake pans and rivets that really kicked it. Just might steal his idea. But the flow rate has to be right and it has to seal up properly, so fabbing one can be tricky. AT least the one I saw was made for a 3.9 Cummins, so the filter should be right. The builder is one seriously talented dude. I wound up reading his entire build thread.
Here is the "cake pan" conversion...
http://www.pirate4x4.com/forum/tow-...e-wc53-tow-rig-vintage-airstream-33.html
More pix on Flickr
Re: Tango's '46 Shorty Bus [Re: Tango] #1274915 Fri Aug 03 2018 08:20 PM
Tango Offline OP
Howdy All --- been a while but I'm still at it. Just finished prepping my window openings for new glass that will go in tomorrow. Lots of little stuff done here and there including getting my E Brake and tranny cables hooked up. All custom made $tuff of course. As usual...new pix in my Flickr Album.
More pix on Flickr
Re: Tango's '46 Shorty Bus [Re: Tango] #1276072 Mon Aug 13 2018 02:20 PM
Tango Offline OP
Got Glass! --- All new Low E glass all around and you can even see through it! Quite a change from the old, chipped, frosty stuff. Been (slowly) working at stripping the paint from the roof and rain gutters on this thing using wire brushes on my 4-1/2 and 7" grinders. A major PITA since some moron decided water based latex house paint was a brilliant idea. It was not. The multiple layers are a bear to get off (where it isn't already flaking off) and where it is off (surprise!) ...is rust. Water on metal is never a good idea. Even Detroit is having fits with the new EPA friendly, water based primers. Been going through wire brushes at an alarming rate. Stuff wont sand (plugs it up)...flap disks eat too much metal...and stripper pads are expensive and get chewed up quickly with all the exposed nuts, bolts and screws on this relic. Still having to use a little liquid stripper here and there but trying to keep it to a minimum. Hate that stuff and typically burn the crap out of myself with it not to mention what it does to your lungs.
Oh well, back to work.
More pix on Flickr
Re: Tango's '46 Shorty Bus [Re: Tango] #1276086 Mon Aug 13 2018 03:57 PM
Rustoholic Offline
Have you tried soda blasting the paint off? The baking soda removes paint but does not harm the metal below.
I haven't used it, but I don't restore stuff either. ;-)
Cheers, Dean
Dean 'Rustoholic' Meltz
Lurch: 1927 1-Ton Chevy Cattle Truck
Old and ugly is beautiful! -- The Saga
More fun with Lurch
Justin: 1928 Chevrolet AB Canopy Express
More pix
Re: Tango's '46 Shorty Bus [Re: Rustoholic] #1276096 Mon Aug 13 2018 05:04 PM
Tango Offline OP
I have heard really bad things about soda blasting from a few hard core builders. It gets into every nook & cranny and is next to impossible to remove so that when the paint goes on...it does not reach the metal. It holds moisture like crazy and starts rusting those areas badly. There are other media that are better/safer but I can't relocate the bus at this time to a facility big enough to handle it anyway.
More pix on Flickr
Re: Tango's '46 Shorty Bus [Re: Tango] #1276404 Wed Aug 15 2018 06:15 PM
Rustoholic Offline
Here's a blurb about plastic bead blasting that might be a viable option: VCCA forum post about plastic bead blasting
Cheers, Dean
More fun with Lurch
More pix
Re: Tango's '46 Shorty Bus [Re: Rustoholic] #1276443 Wed Aug 15 2018 10:37 PM
Tango Offline OP
Plastic beads have gotten really good reviews with the builders I know around here. Just wish I could move this monster to a facility that does it.
More pix on Flickr
Moderated by  J Lucas
Powered by UBB.threads™ PHP Forum Software 7.7.3
