The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 members (tomctomc, TheYeti, WE b OLD, Johnny N, Jimmie D, 1 invisible), 241 guests, and 5 robots.
Forums47
Topics117,681
Posts941,457
Members43,024
Most Online1,229
Jan 21st, 2020
Image Posting Policy
61' 235 into 56' panel
#728428 Thu Mar 10 2011 01:26 AM
guys my 56' 1/2 ton panel has dead 283 and i have running 61' 235 but the 61' has different bellhousing because of hyd. throwout bearing. a friend has a 55' 235 that was in his 52' with 4spd. will this bellhousing work in my 56'? trying to stay local if i can thanks!
Re: 61' 235 into 56' panel
10 micron #728435 Thu Mar 10 2011 01:49 AM
Glad to see you still around. wave
I think you need a bell housing with the angle from a 1955/62. The earlier years took different mounts. If I am wrong I am sure we will hear it!
GMONIZ #728454 Thu Mar 10 2011 02:47 AM
Close to right, George. The change started in '54.
One other problem with the conversion if the truck was a factory 283. The radiator support is too far aft for the six cylinder engine. Since it also supports your fenders, you will have to cut it out, leaving the fenders supported and install another one in the 6 cylinder position.
My TRUCKS website
Cletis #728469 Thu Mar 10 2011 03:12 AM
truck is a factory 235 unit, somebody installed the 283 years ago. the mount for the trans does use a angled mount.
10 micron #728479 Thu Mar 10 2011 03:43 AM
Cletis - the difference in the factory V8/6 cyl core support is position only, the support itself is the same, although the frame brackets have to be moved, cutting the factory rivets .... should be in the assembly manual
squeeze #728512 Thu Mar 10 2011 05:52 AM
Right, the core support is the same. Where it mounts to the frame is different. You must leave the part that attaches to the frame and inner fenders in place or relocate the mount bracket on the frame.
My TRUCKS website
Cletis #728536 Thu Mar 10 2011 12:12 PM
found some old info that i was looking for that confirms 54'-59' has the crossmember that is angled, 53' and back was flat! thanks guys for the help.
Moderated by  tclederman
