The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
8 members (festerhairball, Bolter Finally, Michael Kamer, Leo, 2 invisible), 130 guests, and 4 robots.
Forums60
Topics124,615
Posts1,005,771
Members44,984
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 3 1 2 3
Re: Chevy A833 on a Task Force 235?
alden #724977 Sun Feb 27 2011 05:57 PM
The Van shifter is Hurst, but Hurst OEM shifters are not the same as their after-market shifters. I've found that most of the after market shifters use a 3/8 rod. The Hurst OEM shifter for Mopar uses 7/16 rod.
Larry
I don't own a vehicle that isn't old enough to drink.
LGriffin #727325 Sun Mar 06 2011 08:43 PM
alden Offline OP
Sorry for the 20 questions on this but what year vans should I be looking for?
Does anyone sell replacement linkages new? On the Hurst website they only seem to sell a performance shift kit that has linkage for the full size dodges, but nothing for the vans or chevy trucks and the ones sold for the full size cars doesn't look the same as the one I've got.
alden #727456 Mon Mar 07 2011 03:39 AM
No problem on the questions, the only bad one is the one you didn't ask. Glad to help.
I don't remember what year the one I have came out of. I don't know that the year matters. I saw the Van in a Pick n Pull, it had the right transmission and the shifter was mounted up close to the trans body. here's a pic;
https://picasaweb.google.com/L6Griffin/Transmission
What you found on the Hurst Web site is pretty much what I ran into. I've had some luck finding the MY6 transmission on car-parts.com, put in a year from 1982-86, Chev, 1/2 ton, and you want a side shifter.
Hope that helps,
Larry
LGriffin #727737 Mon Mar 07 2011 11:34 PM
alden Offline OP
I'm finding side cover and top shifter as the common results on car-part. Am I correct in thinking the side cover is the same as the side shifter?
Thanks again for all your help!
alden #727793 Tue Mar 08 2011 02:31 AM
Correct!
LGriffin #728188 Wed Mar 09 2011 12:02 PM
chuckthetruck #728321 Wed Mar 09 2011 07:29 PM
Nice job.
I used the cross member out of a 71 C20 in my 63.
Larry
LGriffin #731161 Sat Mar 19 2011 02:59 AM
I just stumbled on this web page, if your looking for an A833 for your Chev, this page while tell you what Chev they where in.
http://www.drivetrain.com/parts_cat..._kits/a833_new_process_overhaul_kit.html
If your looking for a shifter for your A833 this page will also tell you what Dodge Truck and Vans they were used in.
I have not done business with drivetrain.com and I'm not recommending them, but I may in the future.
Larry
LGriffin #737735 Sat Apr 09 2011 09:32 PM
alden Offline OP
does anyone have the a833 on their stovebolt and could tell me the measurement of the longest linkage of the three. I've found a place that sells them for the various mopar setups and I think if I get them the length they can pick out whichever one matches.
alden #737904 Sun Apr 10 2011 05:07 PM
I'm going to assume that your asking for the length of 1st, 2nd, shift rod. Which is 12.5 inches.
Larry
Page 2 of 3 1 2 3
Moderated by  Woogeroo
