The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (jerrym, bowtietim, bluesman, Grigg, Justhorsenround, GarlandFarms), 80 guests, and 4 spiders.
Forums47
Topics115,096
Posts913,349
Members42,110
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Stuck camshaft 216 #708960
Wed Jan 05 2011 01:05 AM
polaschd  Offline OP
NC
Trying to take down my 216 and camshaft will only slied slightly forward rotaed the shaft and removed the two bolts but still can't get it out any ideas.
Dean
Re: Stuck camshaft 216 [Re: polaschd] #708966
Wed Jan 05 2011 01:16 AM
Frank50  Offline
USA
If I remember correctly the counterweights on the crankshaft just barely clear the camshaft. I think you have to rotate the crank and cam until the timing marks on the gears are aligned with each other then it will pull out.
There may be another problem though. Good luck.
Re: Stuck camshaft 216 [Re: Frank50] #708987
Wed Jan 05 2011 02:35 AM
51 ashton  Offline
kempton,pa
did you remove the dist and lifters?
Re: Stuck camshaft 216 [Re: 51 ashton] #709074
Wed Jan 05 2011 11:34 AM
polaschd  Offline OP
NC
Yes I am down to just the crank and cam cannot remove crank until I can get the cam out and then remove the plate. Any advice would be greatly appreciated.
Dean
Re: Stuck camshaft 216 [Re: polaschd] #709077
Wed Jan 05 2011 12:09 PM
51 ashton  Offline
kempton,pa
if the pan is off look in it and see what is holding it in.
define slightly.
Re: Stuck camshaft 216 [Re: 51 ashton] #709088
Wed Jan 05 2011 02:12 PM
Pete52  Offline
melrose pk. il.
Frank50 is right you have to rotate the crank so the cam can clear it then you can pull the cam out if you're looking at the crank you'll see the crank counter wts. are in the way and hitting the cam bearing journals .
Pete
Re: Stuck camshaft 216 [Re: 51 ashton] #709184
Wed Jan 05 2011 07:53 PM
polaschd  Offline OP
NC
Moves around a 1/4" or so crankshaft is out of the way.
Dean
Re: Stuck camshaft 216 [Re: polaschd] #709202
Wed Jan 05 2011 09:06 PM
Hellomrwilson  Offline
Palestine, Texas
1. Remove all of the lifters and fuel pump. They can interfere with the cam lobes and journals.
2. Remove the distributor.
3. Remove the screws from the cam thrust plate behind the timing gear.
4. Make sure the crank is oriented to clear the cam.
If the cam isn't stuck solid in it's bearings, I can't think af any other thing that could be restricting. Hopefully it's just an oversight and you've already discovered it.
Good luck.
Jerry grin
Re: Stuck camshaft 216 [Re: Hellomrwilson] #709226
Wed Jan 05 2011 10:33 PM
WillH  Offline
De Leon Texas
I remember the cam in my 261 being the same way; it would come out about 1/4" and no more; I could hear/feal it hitting something but couldn't tell what; it finally cam out without forcing but I still don't know what it was hitting; I didn't move the crank. Just work with it a while.
Re: Stuck camshaft 216 [Re: WillH] #709269
Thu Jan 06 2011 01:28 AM
truckernix  Offline
Bracebridge Ontario Canada
Maybe there is something unusual in there that is out of place. I would try looking from the bottom too. If a lobe were hitting something, maybe turning the cam would give you a clue.
1951 1 Ton Completed
Page 1 of 2 1 2
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
