The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (DennisM, 52Carl, Dave Seaver, farmall100, Hugh63c10, C10 - C90 Bill, 1 invisible), 300 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,533
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 3 of 42 1 2 3 4 5 41 42
Re: Disc brake conversion on a 46 2-ton [Re: Hotrod_A] #712410
Sun Jan 16 2011 08:40 PM
RDomeck  Offline OP
Indianapolis, In 46254
I'm using a 1.250 bore master from a 3500HD Chevy and the booster from a 2500 Chevy. The larger trucks use a hydra-boost brake booster and I didn't think putting a power steering pump on the engine would be necessary!
I should have the bracket welded up for the master this week. I'm using the original master bolt holes so there won't be any drilling of holes in the frame.
I'm also remaking the bell crank that mounts in behind the master. My intention for using a more modern brake booster is that the parts and rebuilding of the original brake booster prove to be difficult and time consuming to do. I'm thinking that most of the guys (or girls) that are working on these big old trucks would like something they can pull out of the box and bolt on the parts that are available at there local parts stores.
I'm hoping to have some pictures posted towards the end of the week, but I have a couple of large paying projects that have to leave from my shop this week. I do hope to make some time to put into my truck!
Randy Domeck
Indianapolis Fabrications
rdomeck@me.com
Indianapolis, In. 46254
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #713178
Wed Jan 19 2011 04:04 AM
RDomeck  Offline OP
I got the rotor adapters back from the laser cutter today and I should have bolts in tomorrow. I'n hoping to post some pictures tomorrow!
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #713377
Thu Jan 20 2011 12:29 AM
dmulally  Offline
Sydney, Australia
Hi Randy,
Just a quick note to say that I am still interested.
Cheers
Damian
Re: Disc brake conversion on a 46 2-ton [Re: dmulally] #715134
Tue Jan 25 2011 11:20 PM
fclaridge  Offline
Tenino, WA
Any pics yet? smile
1956 Chevy School Bus Superior Body
More pix in Photobobucket
Re: Disc brake conversion on a 46 2-ton [Re: fclaridge] #715222
Wed Jan 26 2011 04:08 AM
RDomeck  Offline OP
I'm still working on it! I'll take some pictures of what little I have done. I have some adapters for the rotors made, but I don't like them and I am going to have some more machined.
I had them laser cut and I don't like that the rotor doesn't center on a ring. It just center's from the bolts and that doesn't suite me......
I'll be at the machine shop tomorrow to pick up some parts for another job and I'll get them going on the new adapter. I want these to be right before I offer them to you guys.
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #715633
Thu Jan 27 2011 06:21 AM
49' Hayhauler  Offline
Kansas
When you do get something made you will definetly have buyers!!
1949 Chevy 4400 Grainbed
Photobucket pictures
The taxpayers are sending congressmen on expensive trips abroad. It might be worth it except they keep coming back!
Behind every successful rancher is a wife who works in town.
Re: Disc brake conversion on a 46 2-ton [Re: 49' Hayhauler] #716109
Fri Jan 28 2011 09:25 PM
RDomeck  Offline OP
http://s1006.photobucket.com/albums/af184/rrdomeck/1946%202-Ton%20Chevy%20Disc%20Brake%20Conversion/
Enjoy.......
I won't be able to put any more time in on this for a couple of weeks, but it's close to figuring out!
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #718977
Mon Feb 07 2011 02:57 PM
RDomeck  Offline OP
New adapters will be ready in about a week!
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #722072
Fri Feb 18 2011 06:53 AM
c Jason Barnett  Offline
Galena Park, TEXAS!
I have personally seen a guy just remove the 6 rivets/bolts that held the brake drum to the hub of a 1940 Chevrolet 1.5 ton truck. The 6 rivets that held on the brake drum where the same size as the 11" brake rotors off of a 1970's Chevy 4x4. He just bolted the brake rotor directly to the original hub and then just made a simple brakect to hold the caliper and bang he was done. The 6 bolt holes in the modern brake rotor are the same as the six bolt holes on the original brake hub. He was able to keep the stock 10 lug 20" wheels because he didn't change his hub out.
I removed the brake rotors off of a Chevy motor home with the 19.5" wheels , and the rotors look like they will bolt up with no trouble to my 46 Chevy 2 ton.
The aviation artist guy in Houston that loves old trucks even more than planes. www.jasonbarnettartist.com
Re: Disc brake conversion on a 46 2-ton [Re: c Jason Barnett] #722108
Fri Feb 18 2011 02:37 PM
RDomeck  Offline OP
I didn't find that this worked....But I will look at one of those rotor's and find out. My problem with doing this is your putting a much smaller brake than the original drum brake.
The original drums are 14" I don't think you would gain much with going to a 11" disc! The disc that I am using is a 15" and is from a 15,000 lb. vehicle. The same GVW as the 46 2-ton.
The adapters should be ready today or monday! My adapters will center on the hub and have a ring that centers the rotor. A much better design than relying on just the bolt's to center the rotor and hub. In doing the adapter everything runs true....
Randy Domeck
rdomeck@me.com
317-258-0039
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
