The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (Bolter Finally, 1940GmcJoe, carbking, 5ptstar, Dave 64, Cosmo), 265 guests, and 3 spiders.
Forums47
Topics115,648
Posts919,081
Members42,301
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 42 1 2 3 41 42
Disc brake conversion on a 46 1 1/2 and 2-ton #708681 Tue Jan 04 2011 03:53 AM
RDomeck Offline OP
I have the parts coming in from a 3500HD chevy truck with a 15,000lb. GVW. Has anyone ever done a conversion like this. I already have a dual circuit master in place of the old single circuit.
Would there be any interest in making the brackets and rotor mount? I believe I can make an adapter to mount the rotor on the original hub and mount the caliper to the original spindle were the backing plate mounts.
I run a fabrication business and I have done more than a few conversion like this. Just wanted to see if anyone else would like to do this conversion!
Randy Domeck
Indianapolis Fabrications
rdomeck@me.com
Indianapolis, In. 46254
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #708694 Tue Jan 04 2011 04:23 AM
fclaridge Offline
I know I've seen conversion kits for the lighter trucks, but would be interested to know how much a conversion kit for a big truck would cost if there was ever one created. My bus is a 56 1 1/2 ton. Although I just spent almost $500 to have all the drum brakes and components redone I would still be interested in a disc conversion.
1956 Chevy School Bus Superior Body
More pix in Photobobucket
Re: Disc brake conversion on a 46 2-ton [Re: fclaridge] #708699 Tue Jan 04 2011 04:50 AM
webstershotrods Offline
I would like to see the conversion.What bolt pattern do you plan to use ?
Stovebolt Gallery
1952 Chevy 3100
1953 Chevy 4400
1965 Nova
Pics on Photobucket
Re: Disc brake conversion on a 46 2-ton [Re: webstershotrods] #708741 Tue Jan 04 2011 09:16 AM
RDomeck Offline OP
I would still use the original hub so you wouldn't have to change the bolt pattern on the wheels. I'll post some pictures when I get the parts made.
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #708742 Tue Jan 04 2011 09:22 AM
dmulally Offline
Gday Buddy
I would be interested. I have a 51 1.5/2 ton. (not sure which...its huge)
Cheers
Damo
Re: Disc brake conversion on a 46 2-ton [Re: dmulally] #708762 Tue Jan 04 2011 02:30 PM
Grigg Offline
Curious to see what you come up with as well.
I think you'll find that the bolt pattern on the 3500HD axle is the very same as the original truck, with a possible exception of stud size and the old hubs have a smaller wheel pilot diameter, new ones will be 5.25"
Here's another approach using 3500HD and or P-30 axle parts.
In my research and fabricating using the new I-beam as well as the new hubs, rotors, and related parts seemed like the best plan.
http://www.stovebolt.com/techtips/bigbolts/p30swap/
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
Re: Disc brake conversion on a 46 2-ton [Re: Grigg] #709019 Wed Jan 05 2011 05:02 AM
RDomeck Offline OP
I was looking for a little bit less work for the conversion. I know that you can put a different axle under it, but that is a lot of work for someone to do. I am hoping to make a bracket that bolts on he the spindle and make an adapter ring that goes between the original hub and the new rotor. I received the parts in today and will try to fit them up sometime next week.
Would you rather find a complete front axle and spend the time to swap it out or would you rather pull the hub off, mount a rotor to it and bolt a caliper to the spindle and bleed the brakes?
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #709203 Wed Jan 05 2011 09:07 PM
CORPO Offline
I did something like what I think you are planning on doing, perhaps not
Heres what I did, I have not put it on the road yet but all the bracketry is done for the rotors, Im currently working on putting a hydrobooster in my truck to run these twin piston calipers.
http://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=682737&page=1
Im doing alot to my truck, so finishing up the breaks has not been the highest priority...
Re: Disc brake conversion on a 46 2-ton [Re: CORPO] #709230 Wed Jan 05 2011 11:10 PM
RDomeck Offline OP
Corpo, that looks nice. However, I'm looking into putting larger rotors and calipers on. The rotor's are almost 14" that I have here. I should be able to make an adapter ring to go from the hub to the rotor out of 3/8" of 1/2".
I see no reason to use anything thicker then the casted rotor! The mild steel that I will use will be stronger than the cast iron in the rotor. I hope I can mock something up this week. I'll keep you guys posted.
Randy Domeck
rdomeck@me.com
317-258-0039
Re: Disc brake conversion on a 46 2-ton [Re: RDomeck] #709333 Thu Jan 06 2011 04:23 AM
CORPO Offline
Not that it matters, but you can get larger ones then the 12" rotors I used from the higher end after market brake companies.. I know the wilwood kit (for 6 lug GM) has 16" inch rotors, if I recall when I was doing my research there were some that were even bigger... but these kits werent cheep and I was on a budget and didnt need a kit engineered for an Escalade or tahoe... I never did contact them to see what the price of just the rotors would be
I am definitely interested in seeing how your conversion works out, this is my first big bolt, but one day I want to do a COE so I will do it all again...
Are the parts you are using 8 lug? Are you going to machine your adapters or have them CNC from some plate?
Moderated by  John Milliman, Tiny
Powered by UBB.threads™ PHP Forum Software 7.7.3
