The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 registered members (Johnny N, 3B, bowtietim, Boilermaker82, 2 invisible), 590 guests, and 3 spiders.
Forums48
Topics117,145
Posts936,034
Members42,791
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
Removing spring bushing from the frame 55 -59 #703429 Tue Dec 14 2010 06:56 PM
LAJones48 Offline OP
I'm trying to remove/replace the threaded spring bushings from the frame on my 57 Chevy 1/2 ton project. I have a whole set of bushing pullers and drivers, but nothing that will fit the threaded ones that are in the spring hangers. I was thinking of using one of the old threaded pins and a deep socket. Is there a tool still made for this job? Thank you.
Larry
Re: Removing spring bushing from the frame 55 -59 [Re: LAJones48] #703437 Tue Dec 14 2010 07:40 PM
Wrenchbender Ret. Offline
That's the way I do them. Screw an old pin in it & wack away.
1956 Chevy 1/2-Ton Pickup
Re: Removing spring bushing from the frame 55 -59 [Re: Wrenchbender Ret.] #703440 Tue Dec 14 2010 07:55 PM
Thanks. Do you use the same method to install the new ones? I was thinking it would be a good idea not to bang on the new bushings. There is a thread on the tech forum that discusses using a carriage bolt to remove them, but I don't want to distort the new ones as I install them. Thanks.
Larry
Re: Removing spring bushing from the frame 55 -59 [Re: LAJones48] #703453 Tue Dec 14 2010 08:49 PM
alkay3 Offline
I use a balljoint/ujoint press. This works very smooth and easy to get them out and put them back in without deforming the new bushings.
Re: Removing spring bushing from the frame 55 -59 [Re: alkay3] #703470 Tue Dec 14 2010 09:36 PM
tcox Offline
Check the tech tips - there is a good post about this subject. I made the tool described and it worked great for both removal and installation. No beatin' and bangin' - and very cheap and easy.
Re: Removing spring bushing from the frame 55 -59 [Re: tcox] #703505 Wed Dec 15 2010 12:00 AM
tcox,
Is that the one with the carriage bolt? If so yes I saw it, and I am going to try it. Thanks.
Larry
Re: Removing spring bushing from the frame 55 -59 [Re: LAJones48] #703780 Wed Dec 15 2010 10:33 PM
tcox Offline
Yep - worked great for me. Good luck!!
Re: Removing spring bushing from the frame 55 -59 [Re: ] #703888 Thu Dec 16 2010 11:58 AM
Denny Graham Offline
Re: Removing spring bushing from the frame 55 -59 [Re: ] #703981 Thu Dec 16 2010 08:39 PM
Old Dollar Offline
I use this method with a longer bolt and a 1" pipe t to pull against with the new bushing pushing into place while removing the old one. A one step procedure. Out with the old and in with the new. It seems a little quicker. secret
1952 Chevy 3100
More pictures in Photobucket
Doin better'n some an worse than others. Life's what ya make of it. FAMILY, GOD and COUNTRY. Love it or Leave it.
Re: Removing spring bushing from the frame 55 -59 [Re: Old Dollar] #704539 Sat Dec 18 2010 07:53 PM
Thanks. Something else to try while I'm at it.
Larry
Page 1 of 2 1 2
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
