We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,488
Posts1,031,874
Members45,791
Most Online1,229 Jan 21st, 2020
 25 lbs oil pressure in 1956 235?
OP
Just a quick question. I have a chance to replace my original 216/3speed/etc. with a 56 Hydraulic lifter 235/ t5 and open drive. My issue is with the 235, it runs good but the oil pressure at 1800rpms/60 mph is 25lbs. specs say 35 at speed. what to worry about?
 Re: 25 lbs in 1956 235
I have a 56' 235 in my 49' 3600 and it runs at 25lbs also.
1949 Chevy 3600 1975 W-25 Hurst Olds 1991 Chevy Silverado 1970 GMC 1/2 ton Fleetside 2010 Chevy Silverado I'm a GM man!
The Idle oil pressure tells more about bearing clearances. If you get about 15 PSI at idle you are good.
See the USA in your vintage Chevrolet! My Blog
OP
THX for the replies. She runs at about 15 lbs at idle when warm and 25 lbs at 2000 rpms. It's a little hard to tell as the guage messures 0 to 100Lbs. THX again.
