The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (89sbr), 292 guests, and 0 spiders.
Forums47
Topics115,013
Posts912,553
Members42,079
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 2 of 3 1 2 3
Re: 292 Hop up - virtual build [Re: handtight] #685546
Wed Oct 13 2010 01:47 AM
Hotrod Lincoln  Offline
Boltergeist
Dellrose, TN
Nitrous doesn't burn- - - - -it's an oxidizer. When it encounters the heat of the combustion chamber it breaks down and releases oxygen into the mix. Use plenty of NOx, but add enough fuel that it gets burned- - - -not the pistons and valves. Hot oxygen is like a sailor on shore leave- - - -it's going to combine with something RIGHT NOW!
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: 292 Hop up - virtual build [Re: Hotrod Lincoln] #685642
Wed Oct 13 2010 04:45 AM
panic  Offline
Long Island
CH3No2
Don't know what that is, but it's not an alcohol.
All of them are related, and have very similar molecules:
Methanol CH3OH, ethanol C2H5OH, isopropyl C3H7OH, butyl C4H9OH, etc.
Re: 292 Hop up - virtual build [Re: handtight] #685849
Wed Oct 13 2010 09:12 PM
jomichael  Offline
Vero Beach, Florida
If this guy can make a straight 6 Thriftmaster do this, then I would think you can.
NAPCO burnout
Granted those are skinny tires, but geez.
Re: 292 Hop up - virtual build [Re: jomichael] #685917
Thu Oct 14 2010 12:54 AM
handtight  Offline
sol calif
Sorry about the post I am brand new. Lets start again. Nitrous with gas will burn straight across the piston. Methanol and CH3No2 that is nitromethane will burn straight across the piston. The piston needs to be pushed down the cylinder straight not like the gas fired motor that pinpoints the piston.
1940 Chevy 1 1/2 ton, 1959 Chevy 1/2 ton, 1966 Chevy C20.
I can explain it to you but I can't help you understand it.
Re: 292 Hop up - virtual build [Re: handtight] #685972
Thu Oct 14 2010 02:55 AM
panic  Offline
Long Island
Source of this information is...?
Re: 292 Hop up - virtual build [Re: panic] #685980
Thu Oct 14 2010 03:31 AM
handtight  Offline
sol calif
I have ran both nitrous and nitromethane. I still have the old Marvin Miller system back in the 60's. I build my own jets for nitrous. I also have a set of Hilborns and my hydrometer.
Re: 292 Hop up - virtual build [Re: handtight] #686226
Thu Oct 14 2010 10:57 PM
panic  Offline
Long Island
Yes, and the source of this information is...?
Re: 292 Hop up - virtual build [Re: panic] #686318
Fri Oct 15 2010 03:17 AM
SCPOUSN  Offline
KEMPTON, PA
I built a 292, crower stage 3 hydraulic 262/480/490lift, bigger valves 1.94/1.60, edelbrock 500, harland sharp rockers, lumps, ported/polished, mallory distributor, I used LP pistons shaved the block&head for a true 9:5/1 comp ratio, took the head to 70cc's, langdon exhaust flanges and clifford intake, balanced all, with a saginaw 4 spd and posi rear 3:23 gear, let me tell you that motor "GOES" i have it in my 1953 chevy 3100, now mind you I could of built a super small block for what I have into it, but everybody has small blocks, you have to pay to be different!!forget the virtual just build it!!
Re: 292 Hop up - virtual build [Re: SCPOUSN] #686418
Fri Oct 15 2010 04:14 PM
Joe H  Offline
Lee's Summit Mo. 64086
And forget the nitrous. Yes it makes hp and torque, but only till the bottle runs out, which is about 5 or 6 passes at the dragstrip. Nitrous is for dyno numbers and race cars!
Joe
Re: 292 Hop up - virtual build [Re: panic] #687615
Wed Oct 20 2010 01:31 AM
handtight  Offline
sol calif
Page 2 of 3 1 2 3
Moderated by  KCMongo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
