The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
16 registered members (48bigtrucks, D B Cooper, 52Carl, baldeagle, 5 invisible), 300 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,529
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
How easy to rebuild 1958 steering box? #631750
Wed Mar 24 2010 03:29 PM
bigdog58  Offline OP
Idaho
I appreciate any and all advice I get from you guys for sure.
I posted regarding fromt end wobble and all things point to the only thing left which is the steering box. Who in here has attempted this project and how did it turn out? Pretty sure that I can do it but need to hear from a few of you as to the possible issues I may or may not face.
Thanks in advance, Steve in Idaho
Re: How easy to rebuild 1958 steering box? [Re: bigdog58] #631760
Wed Mar 24 2010 04:31 PM
rfs56trk  Offline
Seal Beach, CA
What I have found in the few that I have dissassembled (both cars and trucks) is that the bearing surface on the worm shaft is damaged. Generally the upper bearing runs out of grease and wipes out the bearing and the shaft becomes badly pitted. This surface is hard chrome and could be redone or the shaft replaced. There are kits available with bearings and small parts and the book gives a good rebuild procedure. There are a couple of sources in my area that do a good job rebuilding steering boxes and are reasonable.
Fred
Re: How easy to rebuild 1958 steering box? [Re: rfs56trk] #631765
Wed Mar 24 2010 04:48 PM
bigdog58  Offline OP
Idaho
Do you have instructions on how to remove the column? Looks like I have to drob the exhaust and jack it up pretty high to get it out. I did find the place in San Jose, CA which will rebuild it for $275. Do you have another source for rebuild?
Thanks Fred,
Steve
Re: How easy to rebuild 1958 steering box? [Re: bigdog58] #631962
Thu Mar 25 2010 04:16 AM
Joe H  Offline
Lee's Summit Mo. 64086
Re: How easy to rebuild 1958 steering box? [Re: Joe H] #632230
Fri Mar 26 2010 03:45 AM
rfs56trk  Offline
Seal Beach, CA
You will need a pitman arm puller. Set it up on stands, remove the wheel, pitman arm, steering wheel, turn signal, dash clamp, shift linkage, and mounting bolts and the whole column/gear box comes right out. If you have a V-8 truck, you will have to remove the left manifold. It should clear on a 6 cyl.
I have used ABS in Orange CA. www.abspowerbrake.com.
Fred
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
