The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Gone, 69Cuda, EdPruss, Hambone, DougMac, fixite7), 163 guests, and 3 robots.
Forums60
Topics124,048
Posts1,001,112
Members44,825
Most Online1,229
Jan 21st, 2020
Image Posting Policy
intake rings
#61760 Thu Jun 15 2006 02:43 AM
Junior Member
How important is the rings that seal the intake manifold to the head? I have a late 235 and am using a early 235 intake/exhaust and the rings would not fit in the block so I left them out. Now the engine does do run unless 80% choke is used and backfires thru the carb once the choke is pushed in. ????leaking intake manifold??? Do I need a late 235 intake and rings for a correct fit???
Re: intake rings
#61761 Thu Jun 15 2006 05:19 AM
I think if you use 216 gaskets you could get away without using the rings. On jobs where I use the 216/early 235 manifold on a late 235 I make bushings to fit in the head to reduce the size so I can use the smaller alignment rings.
My Blog
Re: intake rings
#61762 Thu Jun 15 2006 03:03 PM
V
You're using a 216 intake manifold and it'll always leak unless you make up some stepped rings , it is far easier to just get a good used 235 intake manifold , remember the truck intake manifold has a horn mount boss on it drilled & tapped , some car intakes have the boss but it's not drilled and tapped .
How you tighten it up is important too , begin tightening in the center and work outwards .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
Re: intake rings
#61763 Thu Jun 15 2006 05:05 PM
I've bored the (3) intake ports on lots of 216 intakes from 1.437 to 1.531 to allow the use of the 235 rings. Then everything fits right together.
Re: intake rings
#61764 Thu Jun 15 2006 06:17 PM
Barry,what do you use to bore out the ports?What works the best?
Wanted Good Woman:
Must be able to cook , clean , sew , tune engines and polish trucks. Must have old Stovebolt and garage. Please send picture of old Stovebolt and garage.
Re: intake rings
#61765 Thu Jun 15 2006 08:15 PM
I do them on a Bridgeport (milling machine). It should be a pretty simple (inexpensive) deal to have done if you have a good, small, local machine shop or know a buddy with a mill in his basement or garage. Many engine rebuilding type machine shops may not be equipped to do this however, as they usually just have the equipment to bore blocks and do head work.
Re: intake rings
#61766 Thu Jun 15 2006 08:47 PM
Barry is the best! grin
Joe smile
See Joe Fuchs' 1937 Chevrolet 1/2 Ton Pick Up on Facebook at The Top Of My Page. Go to: Joe Fuchs on Facebook
Moderated by  Woogeroo
