Time to hit the roads!
STOVEBOLTING!
Ready to get the truck on the road?
The Side Lot has the places with some action! From West to East, South to North ... into Canada, of course!
Some groups have posted events that cover your roaming area.
Check in for starters, and check back often. Might be missing something like this or some variety.
Searching the Site
2023 Old Truck Calendars
First one
Nothing like old trucks working
2023 Stovebolt Calendars
Check for details!
12 members (DennisM, Bob King, ESum, 78buckshot, DannyW, D B Cooper), 214 guests, and 3 robots.
Forums60
Topics128,833
Posts1,060,423
Members46,767
Most Online1,229
Jan 21st, 2020
#599047 Mon Dec 07 2009 07:16 PM
panic Offline OP
For those who haven't seen it:
http://tinyurl.com/yfug9cf
It didn't go for much, did someone here get it?
I'd be most interested in exchanging comments on adding downdraft ports by insertion with the buyer.
BTW: the new irritating method that eBay uses to prevent downloading pictures can be bypassed with some work.
1. click to select which view, then "enlarge"
2. press both CTRL and + several times to fill the visible screen
3. press both CTRL and PRTSCR (print screen) to copy the image to your clipboard
4. now open Photoshop, Imager, Paint, etc. and paste the image in a new field
"MONGO"
Interesting I'd also be interested in seeing how this was done. Would love to get some High Res pics of the head without the carbs attached. I've got a couple stripped heads stored away with a similar modification in mind.
Steve
Mongo's Garage [mongosgarage.com]
Vintage GM Truck's & Parts
panic Offline OP
I'm a bit surprised at the entry angle and location, since it looks like it goes very close to the guide boss.
I wonder if he did this simply to avoid making a curve to accommodate the down-draft Rochesters, or was this because of some structure inside the casting (water, support boss, ?) that we can't see?
The original Rajo conversion had a much less severe angle, and entered above the original ports, but left the valve cover sealing surface untouched.
