The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
2 members (blueck, ApacheFiend), 151 guests, and 3 robots.
Forums50
Topics121,036
Posts970,299
Members43,817
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 3 1 2 3
Fuel Petcock Valve on a 53'
#597648 Wed Dec 02 2009 10:30 PM
Pulling the gas tank on my 53' 1/2 ton, and I came across what appears to be a fuel petcock valve. All of the diagrams I have seen for the 47-53 pickups have the fuel line connecting to a rubber hose that enters the passenger compartment from the underside. In the pictures it looks like this line connects to a steel line which enters that tank at the top. However the valve connects to the fuel tank at the bottom. I have included a picture, please note that 1/2 inch bolt at the bottom is stripped and the lever broke off when I attempted to turn it. Thought I'd ask about it before I remove the whole thing, and bypass it.
http://www.flickr.com/photos/kaliforniaman/4153731374/
Steve
49' 3100 5-Window
Re: Fuel Petcock Valve on a 53'
Kaliforniaman #597655 Wed Dec 02 2009 10:48 PM
Not aware of a factory fuel valve. I would guess that was an add on from a previous owner, perhaps there was an aux. tank installed at one time?
Allan
1951 GMC 1/2-ton
Two 1953 Chevy 3100 5-window
Here's the most recent one
Synthetic Lubricants
magfarm51 #597657 Wed Dec 02 2009 11:07 PM
Allen I have to disagree with you up to a point. I don't know if all the 1/2 ton trucks came with a shutoff valve or not. However reading a great number of posts on the subject, It is my understanding most of them did come with a shutoff valve. It is a shame that kaliforniaman broke the original valve. They are hard to find, and the repops are not quite the same. If I don't have my info 100% someone that can speak to the valve issue will chime in. Jim.
magfarm51 #597658 Wed Dec 02 2009 11:08 PM
ace skiver
A shut-off valve was supposedly used through 1953, The location of the fuel line into the tank changed in 1954.
Tim
1954Advance-Design.com [1954advance-design.com]
1954 3106 Carryall Suburban [stovebolt.com] - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic [1954advance-design.com] - part of the family for 15 years
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engines are not "splash oilers" - this is a splash oiler. [chevy.oldcarmanualproject.com]
tclederman #597659 Wed Dec 02 2009 11:15 PM
Hi Tim,
Just to double check, so you like me think 1/2 tons did come with the valve from the factory? Jim
Jimmie D #597661 Wed Dec 02 2009 11:20 PM
My '50 was an 'unmolested' truck when I got it.
There was a brass fuel petcock.
I had more luck than Kaliforniaman though, I managed to get mine freed off.
I just need to get the tank cleaned out now!
More pix on Flickr .
jockbolter50 #597663 Wed Dec 02 2009 11:27 PM
JB,
I have not got a mirror up high enough to look, was the petcock valve threaded for the tank line, or is it part of the line which connects to the tank? If it is threaded, I should be able to twist-off the whole valve. However, if that is the case I am not sure what the stripped bolt would be for.
Steve
49' 3100 5-Window
Kaliforniaman #597665 Wed Dec 02 2009 11:34 PM
my '50 has ths valve, there is a brass nipple (about 3" long) between it & the gas tank, the valve is made like a cross, the top goes up to the tank, bottom has a cleanout plug, the shutoff is on one side, rubber fuel line connects the other side to the metal fuel line.
here's a pic, http://memimage.cardomain.com/ride_images/2/2877/4121/19692060138_large.jpg
wv_hillbilly #597675 Thu Dec 03 2009 12:23 AM
Then the stripped bolt is the clean-out. Seems like I should replace it. Jimmie D. is correct, I have not found an exact replacement. I did find some made for motorcycles:
http://www.golanproducts.com/fuel_valves.html
Steve
49' 3100 5-Window
Kaliforniaman #597710 Thu Dec 03 2009 01:58 AM
My 53 has the valve. You can have mine if you have the time to wait until I get back up to Wisconsin as I am converting mine to a diesel.
However my grandfather was in the plumbing business for a long time and owned a hardware store for a while in the 50's-70's. I have seen the vary same valve in the hardware bins in his storage shed before he pasted away.
Page 1 of 3 1 2 3
Moderated by  Justhorsenround
