The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
What's going on?
What's happening?
Find out in
THE SHOPS !
Genearl Truck Talk
20,267 threads; 177,521 posts
The Engine Shop
32,460 threads; 255,065 post
Driveline
8,796 threads; 65,970 posts
The Electrical Bay
9,505 threads; 74,285 posts
Sub: The Radio Bench
The HiPo Shop
5,040 threads; 46,029 posts
Paint & Body Shop
12,505 threads; 81,120 posts
Sub: The Doors
Interiors
4,059 threads; 26,817 posts
The Tool Chest
1,762 threads; 26,817 posts
Making a Stovebolt Bed
1,052 threads; 6,659 posts
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (john l miller), 63 guests, and 3 robots.
Forums59
Topics128,612
Posts1,041,913
Members46,061
Most Online1,229
Jan 21st, 2020
#595097 Tue Nov 24 2009 04:34 AM
The motor in my '49 fresh-air heater has been wired up and working for several months. Yesterday, I connected the hoses to the radiator and decided to go for a test drive. Some warm air in the cab would feel nice this time of year.
I had been driving for about 10 minutes, with the heater on, when all of a sudden - BANG! I heard a loud firecracker-type explosion and saw a puff of smoke from the heater. My life flashed before my eyes because I was not only driving, but afraid my 3-year project was about to burn to the ground.
I turned the heater off and managed to pull over and stop. Fortunately, no fire. After my heart rate dropped below 100, and I looked more closely, I noticed that the voltage reducer on the heater had essentially exploded. It was in several small pieces inside the cab.
The truck is 12-volt, and the voltage reducer was supposed to drop the voltage from 12-volts to 6-volts for the old motor. The voltage reducer was brand new from a favorite vendor.
What caused this?? Anybody else have this problem? Did the voltage reducer overheat? I had assumed the old motor was 6-volt, but there are no markings on it anywhere. How do I confirm that it's a 6-volt motor? All is good, now, but that was definitely a scary moment.
Sounds like something shorted to ground. Might need to check that motor out to make sure there isn't some sort of internal issue.
Bill Burmeister
LONGBOX55 #595165 Tue Nov 24 2009 12:48 PM
They sell a resistor that is in a ribbed metal case and has a mounting hole at each end. It is usually described as "heavy duty". It is around 1 ohm in value. These can be used for an original radio or a heater. One of our members bought one for his AD radio and it blew up just like yours. The second one, a replacement, was OK.
Yep, that's exactly what I had. Ribbed metal case, gold color, mounting holes at each end, described as heavy duty and made for heaters. The cost was $18.25.
Not to switch topics here, but I see that a whole new 12-volt motor is only $49.95, and most of the vendors sell them. Has anybody successfully swapped their motor recently? Any problems? Where did you buy the motor?
easy fix - take your old motor to a local parts store and match details [shaft size, rotation and rpm] in 12V
squeeze #595235 Tue Nov 24 2009 05:44 PM
Truckernix,That was me it happened to.I was bench testing an AD radio and the reducer popped like a firecracker,thought i fried the radio.I took it back and exchanged it for another one,everything was fine.
I installed a 12 volt heater motor that Jim Carter sells.You have to drill re-drill a couple of holes to mount it center.I think i had to make a new rubber gasket at the firewall.The new motor was smaller in diameter.
If you decide to get another reducer,make sure you have it mounted flush to the dash panel.The dash metal will act as a heat sink for the reducer,keeping it cooler.Be sure no electrical wiring is close to the reducer,it will melt it.
"A house is built with boards and beams,a home is built with love and dreams"
Look deep before you leep !!!
"Everything is Everything"
"If I say a mouse can pull a house,Hitch him up"
My 1951 3100 Chevrolet
My 1951 Chevrolet Suburban Carryall
bowtietim #595246 Tue Nov 24 2009 06:40 PM
Ex Hall Monitor
OR you could do like I did on my 55.1 panel and just run it on 12v. I never had an issue with the motor running on 12 for over 100K after I converted it to 12v.
Let's go Jared!
Tiny #595261 Tue Nov 24 2009 07:35 PM
We have had nothin' but problems with voltage reducers on heaters for years now.
Because they get hot & want to melt & burn everything around them { not to mention explode }....We don't mess with them anymore...
We install new 12 volt motors in them but, it is tough finding an exact replacement motor that has the same overall dimensions with the correct keyway pad for the blower cage set screw.
We got lucky & found replacement 12 motors at an electrical supply store that was going out of business a few years ago & we stocked up.
http://members.cox.net/marshallgulch/Img_4180.jpg
I disconnected the voltage reducer and tried running the 6-volt motor on 12-volts. The motor runs fine, but the heater switch located left of the steering column literally turned red hot and started smoking. The switch always gets very hot, which I understand is normal, but apparently the additional heat that cause the voltage reducer to explode was now being dissipated through the switch. I quickly decided this was not a workable solution and shut her down.
So, my options are to install a new voltage reducer or swap the 6-volt motor to a 12-volt motor. I was leaning toward replacing the voltage reducer, because I found an on-line store that sells them for half the price, and installation would be much easier than replacing the motor. However, the heat at the switch got me to thinking about which option would be best for my switch. If I install a 12-volt motor, will the heater switch run cooler, or would the switch run the same temperature as a 6-volt motor with a new voltage reducer?? I'm thinking the 12-volt motor runs at half the amperage as the 6-volt motor, so maybe my switch gets half as hot. Any thoughts on this?
Replacing the motor is not that hard if your heater is like my fresh air unit. Probably be cheaper in the long run too.
Fried Green T'mater (Vern)
1953 Chevrolet 3600
More pix on Photobucket
Caution: Political Statement
Moderated by  Rusty Rod
