The Stovebolt.com Forums Home | FAQ | Gallery | Tech Tips | Events | Features | Search
Thanksgiving
Much to be
thankful for
YOU!
The Stovebolt Collective
Thankfulness year 'round.
All around!
Searching the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
0 members (), 66 guests, and 3 robots.
Forums60
Topics127,652
Posts1,046,325
Members46,394
Most Online1,229
Jan 21st, 2020
#594297 Sat Nov 21 2009 01:40 PM
Decided to take the '49 out yesterday for one last spin. I installed a regulator valve for the fresh air heater a while back and noticed yesterday that the heater never really blew out warm air. Just cool air no matter where I turned the knob on the valve. Did I do something wrong on the install? Hoping someone might have an idea. Thanks
My truck: She may not be the prettiest girl at the dance, but she's all mine!
pablos49 #594303 Sat Nov 21 2009 02:23 PM
Could it be air locked? somtimes there is some air in the heater and the coolent will not push it out because the air compesses and the coolent will not move , the best way to get the last of the air out is to loosen the return line the lower one coming from the heater a little and let the engine run the air pocket sould come right out and the hoses should start getting hot .
Pete
Pete52 #594311 Sat Nov 21 2009 03:25 PM
Thanks, Pete. I'm going to give that a try in a little bit.
pablos49 #594382 Sat Nov 21 2009 08:42 PM
I am thinking you do not have the heater hoses hooked up properly.
Here is the factory diagram that shows the correct routing of the hoses.
http://members.cox.net/images4755/freshairheaterhosehookup.jpg
I tried Pete's idea. Between that and adding about a quart of anti-freeze I now have heat. Thanks for the help.
Moderated by  ndkid275, Phak1
