The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Nothing new here ...
STOVEBOLT FEVER
There is no cure!
Thanks to all of you, we have been virtual for over 25 years.
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
26 members (5 Window 9434, cmayna, Bill Marlow, 50wudy, 55 SHAKER, archburycontrol, 1 invisible), 109 guests, and 3 robots.
Forums47
Topics117,794
Posts942,573
Members43,043
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
54 vs 55 1st series 3100
#58172 Thu Mar 23 2006 03:52 AM
Brian54 Offline OP
Apprentice
Could somebody out there please tell me the difference between the 54 & 55 1st series 3100? Thanks
Re: 54 vs 55 1st series 3100
#58173 Thu Mar 23 2006 03:57 AM
A model year? I don't think there's any other difference,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
#58174 Thu Mar 23 2006 04:44 AM
ace skiver
Different side emblems on the hood.
Open driveshaft in 1955-1st.
H55 as the first three characters on the door hinge pillar plate for 1955-1st; H54 for 1954.
Different shades/names for the "white" top on the exterior two-tone deluxe cab.
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
#58175 Thu Mar 23 2006 11:03 PM
Like TC says the main difference is the open drive shaft on the 55-1. There is also a different water pump & pulleys. I believe the 55 is 12 volts. Someone correct me if i,m wrong.
1956 Chevy 1/2-Ton Pickup
#58176 Fri Mar 24 2006 03:52 AM
The '55 1st Chevy I have is six volt.
Its true, I really don't do anything but browse the Internet looking for trouble...
Steve@OldSub.com . www.OldSub.com . www.MaxwellGarage.com . www.OldGasTowRigs.com
'55 1st GMC Suburban . '54 GMC 250 trailer puller project. '54 GMC 250 Hydra-Matic . '54 Chevy 3100 . '47 Chevy COE . and more...
#58177 Fri Mar 24 2006 12:49 PM
55 1st ser is 6 volt...doc
#58178 Fri Mar 24 2006 06:30 PM
A significant difference is the open drivetrain. Both have 3.90 differential but if you intend to keep the rear axle and swap gears you can go with 3.38 while the 54 swap is for 3.55. The rear springs are the same overall length but the "center" hole is located differently. The 54 rear spring mounts to an offset rubber insulated "projection" off the axle while the 55.1 bolts directly to the axle. In 54 the grill background color is white but is black on 55.1.
Mike
1950 GMC 1-ton pickup, 55.1 Chevy 1/2 ton pickup
#58179 Fri Mar 24 2006 07:59 PM
Chrome grills were offered for the 55.. 6v trucks...biggest difference is the hotchkiss rear end...no torque tube...and as pointed out the--option now to go to 3:38 gears. The 55.1 (the last of the breed) was factory superior to the 54 from a highway perspective and incorporated the open rear end which virtually all rodders of prior year AD trucks perform on their trucks to make them hiway capable.
Importantly, the 55.1 was only in production for 1/2 year and in my experience is far more difficult to locate.
Buzz'n Half Dozen
#58180 Sat Mar 25 2006 01:09 AM
ace skiver
50GMC253,
I am very interested in knowing more about 1955-1st grills. It is my understanding that the standard 1955-1st grill is all white (no "inner" and "outer" grill different in color). Is that correct?
When you state "In 54 the grill background color is white but is black on 55.1.", are you referring to the chrome grills for both years?
Tim
Tim
#58181 Sat Mar 25 2006 07:23 PM
I guess we're back to posting the same question in multiple forums again...
As far as the grilles go, my 54 4400 is solid white.
1954 GMC De Luxe COE
Page 1 of 2 1 2
Moderated by  Woogeroo
