The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Big THANKS to
MONGO
for hosting
the weekend event.
Read all about it.
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 members (NorthCoast3800, klhansen, ronsway, 1 invisible), 89 guests, and 3 robots.
Forums60
Topics124,721
Posts1,006,680
Members45,016
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
12volt radio dash mounted in a '50s chevy
#571700 Sat Sep 05 2009 06:23 PM
Here is one way to get tunes in your ride. Use a 12 volt cassette radio with the a pot on each side. Remove the cover, unscrew the pots and pull the wires or ribbon cables outward. Cut holes in the cover to accommodate the wires. A radio with a U shaped cover is easier to modify. A radio with a flat cover may need to be completely dismantled to get the sides off. Use a radio hole plug for the mounting bracket. Cut a hole in it for the radio front. Screw the bracket to the radio chassis, these screws will be behind the dash. The pot shafts will secure this assembly to the dash. Add spacers between the bracket and the radio to set the radio back, so the knobs are close to the dash.
[IMG]http://thumb9.webshots.net/t/55/855/5/16/6/2910516060094727889srfLJm_th.jpg[/IMG]
[IMG]http://thumb9.webshots.net/t/55/855/0/46/37/2491046370094727889vZLkco_th.jpg[/IMG]
[IMG]http://thumb9.webshots.net/t/68/468/2/99/80/2933299800094727889OMLEhO_th.jpg[/IMG]
[IMG]http://thumb9.webshots.net/t/96/96/8/98/18/2366898180094727889iTwdaE_th.jpg[/IMG]
1947.2 Chevy Panel Truck 1 ton
1955.2 Chevy Suburban
1955.2 Chevy 6700 Bus/RV
Re: 12volt radio dash mounted in a '50s chevy
walterhvogel #575517 Fri Sep 18 2009 06:38 PM
ODSS President
This is great information, please re-size your photos so that we can get a good look.
Regards,
Cosmo
Cosmo
"...my good horse Rocinante ('49 Chevy Half Ton), mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes
Cosmo #791433 Sun Oct 23 2011 06:11 AM
walterhvogel #791687 Mon Oct 24 2011 05:33 AM
Yes, your link di work, but I would have put in an older style CD player so you di not get the light show like what's on the newer one's. Just my $0.02 though. Looks great though! How di you manage to fit that in there? Did you have to move arund anything under the dash?
walterhvogel #1146429 Sun Jan 24 2016 10:16 PM
walterhvogel #1146450 Sun Jan 24 2016 11:56 PM
Gas Pumper
I wish the PO on my truck had done this, but NOOOOOOO, he decided to take a tin snips and just cut a hole in the dash for his radio to fit. I have the old part of the dash before I put the replacement in as a souvenir.
http://devestechnet.com/Images/Restorations/1950B/D50b00044lg.jpg
http://devestechnet.com/Images/Restorations/1950B/D50b01002lg.jpg
What to do, and then what NOT to do! Nice job!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
walterhvogel #1146456 Mon Jan 25 2016 12:53 AM
Is anyone reproducing the radio delete plate?
walterhvogel #1146490 Mon Jan 25 2016 03:28 AM
Seems I've seen them offered somewhere....I think. Expensive though if I remember correctly.
And ad in the Swap Meet will probably turn one up for you.
1937 Chevy Pickup [stovebolt.com]
1952 Chevy Panel [stovebolt.com]
52 Chevy Panel [photos.app.goo.gl]
Pictures in my Photobucket [s140.photobucket.com]
https://photos.websearch.com/share/...Nko1cUJCNFFMTVFEUnNRbjFhNTFPc1J4YWV4cmRB
walterhvogel #1147609 Mon Feb 01 2016 04:23 AM
I actually installed the cassett deck from an 85 monte carlo ss that i had. It fit surprisingly well, a bit tight on the control arms but wasnt bad
walterhvogel #1147611 Mon Feb 01 2016 04:24 AM
Also links arent working
walterhvogel #1147647 Mon Feb 01 2016 01:01 PM
7 years old thread
He updated the link for cassette deck mod on 1/24/16
DADS50 #1418526 Wed Jul 28 2021 05:36 PM
Someone recently asked about modifying an old radio to get FM in their truck, and I remembered this old post. I just discovered the picture links are dead, so here are the pictures. I used a stereo with knobs, probably '80's vintage. Pull the potentiometers out of the chassis. Modify the radio delete panel. I ran it this way for years. The original radio is big, so there is plenty of room behind the dash.
walterhvogel #1418985 Sun Aug 01 2021 12:53 PM
Modern radios usually look like a JC Whitney blob dropped in the middle of the dash. We "French" a mount plate for the exact radio used and it gives a much smoother look. Many customers have chose this option but it needs done before dash is finished/painted.
[img]https://i.postimg.cc/67Yg1fbH/dan-s-49-010.jpg[/img] [postimg.cc]
Evan
Page 1 of 2 1 2
Moderated by  ndkid275
