The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Positive thinking ...
We are still asking:
What did you
get done on
your Bolt today
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt
this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures
and No BOTS.
So ...
What did you get done on your Bolt today????
Stovebolt Site Search
Oh Lord, I just gotta find it....
A pdf guide to help you search the Site
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
5 members (klhansen, Shaffer's1950, Dakotabolt, Rsqwhite, 1 invisible), 107 guests, and 1 robot.
Forums60
Topics127,470
Posts1,031,724
Members45,787
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 2 1 2
how to tell what engine, tranny truck should have
#570457 Tue Sep 01 2009 11:28 PM
trevota Offline OP
hey I've been looking around and found a couple usefull sites, but i am still unsure how to tell what engine my truck came with from the factory. Hopefully you guys can help or point me in the right direction.
vin# C2545Z1628 on the plate on the driverside kick panel it had:
7500
RPO STD tranny??
525AA paint code? 525 is fawn
127
http://www.americanclassic.com/paint.htm?p1=vin
Thats the site i found, but i cant figure out the engine/ tranny info.
Reason im curious is my truck has a 6cyl in it now. According to the previous owner, and other obivous modifactions they did to put a straight6 in, im sure it had a v8 to start with.
some info: 65' , its a 3/4ton has what looks like a factory 4 on the floor with the high hump floor.
Re: how to tell what engine, tranny truck should have
trevota #570486 Wed Sep 02 2009 12:53 AM
since it has the high hump pan i bet it was originally a sm420 4 speed. what kind mods make it known it has been changed to 6 cyl?
hoggyrubber #570590 Wed Sep 02 2009 12:29 PM
I gotta ask 'cause I keep hearing about the high hump tranny tunnel.
Was this only on C20's and bigger or was this something the factory also did on C10's?
Can you explain more about the "high hump" floor pan? Got any dimensions as far as what is standard tranny tunnel height vs. "high hump"?
Hot Rod John #570595 Wed Sep 02 2009 01:14 PM
I do know that my 66 c10 has a high hump with a transfer case shifter hole because the PO put a sm420 in and it fits right in. so I'm guessing 4x4s had it. I'll measure it when I get home.
"The Marines I have seen around the world have the cleanest bodies, the filthiest minds, the highest morale, and the lowest morals of any group of animals I have ever seen. Thank God for the United States Marine Corps!"
Elanor Roosevelt
1966 c-10 stepside
1966 c-10 fleetside
1964 c-10 fleetside
1964 c-10 short bed
1964 c-30 flat bed
1964 c-60 dump truck
1968 Impala
1969 Nova
1971 Nova
1975 LUV
1976 C-30
1977 K-20
1966 SS El Camino
David13 #570622 Wed Sep 02 2009 03:10 PM
the 4spd version used the high hump floor all models
ron
padresag #570751 Thu Sep 03 2009 01:32 AM
trevota Offline OP
high hump floors were for the 4spd. the sm420 has a high shift tower on the tranny... thus needing a high hump floor for it to fit.
how i know its not stock, motor mounts have been played with, they are bolted to the frame, not riveted like factory. Truck has a 1976-79 250I6 car engine in it. it has the intake manifold thats integeral to the head. The throttle linkage was mickey moused together. And the previous owner said it is supposed to have a v8 in it, but he did not know if it was a 283 or 327
trevota #570771 Thu Sep 03 2009 02:08 AM
hot rod john, i used to have a 66 c20 with a low hump so not all of them had the high hump. the c20 usually had the 4 speeds though so that's prob why most had them. in fact some of the bigger trucks have neither, they have "no hump" like the 62 and 65 c60's i used to have. no need for measurements, the low hump are round high are more square. trevota, sounds like you are right on since the manifold situation. the motor perches would not have been moved from the v8 to the 250 and the ones i have seen are bolted in not riveted. only the bracket that bolts to block is different. sorry i can't answer what engine was orig in there, i don't know much about the #'s. maybe someone will be able to.
hoggyrubber #570797 Thu Sep 03 2009 03:15 AM
I'm guessing maybe the GMC's all came with the high hump. Mine is a regular 2 wd short 1/2 ton that originally came with the 3 on the tree and it came with high hump. The difference is obvious once you know what to look for. The low hump has a somewhat bellhousing shape transition between the firewall and floor. The cover/pan in front of the seat appears to be about 1-2" tall. The high hump is about 6-7" tall running forward from the seat, and is very square in appearance.
Markeb #570910 Thu Sep 03 2009 02:03 PM
I don't think the 327 was available 'til '66...at least in 10's.
I've had a '74 250, a '66 327, and back to a 6 in my '65 C10 and never had to touch the motor mounts, which are bolted to the frame.
If you can't fix it with a hammer and screwdriver, you need a bigger hammer.
1965 Chevy C10
trevota #570929 Thu Sep 03 2009 03:18 PM
2 wheel drive perches were bolted in while 4 x 4 were rivited in
230 and 250 eng perches were located in the frt 2 frame holes while 283 perches were located in the rear 2 holes. the 292 were offset with the pass side being forward of the other side
ron
Page 1 of 2 1 2
Moderated by  Hambone
