The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (bwilliams, bartender, Athab3, kades51, jiw1, Harold46, 1 invisible), 294 guests, and 3 spiders.
Forums47
Topics116,112
Posts923,261
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 651 of 663 1 2 649 650 651 652 653 662 663
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308637 Fri Apr 26 2019 10:42 AM
popcornBen Offline
Got my new windshield wiper RainGear installed not a bad deal to install! Now putting in my Vintage Air system inside of cab coming together nicely! There is light at the end of the tunnel!
Pops
Pops the truth is out there!
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308727 Sat Apr 27 2019 02:30 PM
Justhorsenround Offline
Grease Monkey, Moderator General Truck Talk & Greasy Spoon
Been doing a bit of rust management on the ‘62 C-10 this week. Just hitting the surface rust spots with a rattle can spray of primer. Found a can of Safety Blue and did a little coverup on the front facing sheet metal. Hoping to hold the rust mites at bay while I save up for a proper paint job. Off to the “Oklahoma Stovebolt GabFest” in a couple of hours. It’ll be fun meeting some new Bolters and catching up with the familiar faces. Watch for photos in the “Hot Wash Forum”.
drive
"I fought the law and the law won" now I are a retired one!
Support those brave men/women who stand the "Thin Blue Line" and lock up those on the wrong side of that line.
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308756 Sat Apr 27 2019 11:22 PM
Bill Trotter Offline
Installed my horn bushing in the steering column on my 37. Took all day as I spent half the time thinking about it. Tried to push the bushing in with steering wheel nut but that didn't work out. Finally pulled the entire steering column with gear box and used a threaded rod to push in bushing. Installed steering wheel and new horn button and moved outside column down a little bit to get contact when button was pushed. Glad that job is done.
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308905 Mon Apr 29 2019 12:12 PM
SLAWNSKI Offline
I got the 235 reassembled this weekend and the crank drilled/tapped for harmonic balancer. Also first coat of paint!
1954 Chevy 3/4-Ton Chevy
"Mo"
1948-53-54 "Mixed Bag" Chevy Stakebed
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308906 Mon Apr 29 2019 12:14 PM
SLAWNSKI Offline
I had no post tapped photo- there it is drilled. I used the 12bolt fixture, drill and tap. Went easier than expected.
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308977 Mon Apr 29 2019 11:28 PM
SLAWNSKI Offline
Last coat sprayed tonight. Good enough for a driver. Happy with the results.
"Mo"
"Basket Case"
1952 Chevy 3/4-Ton
"as yet un-named"
Lots of pictures
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1308994 Tue Apr 30 2019 01:28 AM
Spotbiltxo Offline
Nice work Slawnski. Boy, that sure is a bright blue! Looks nice.
Chuck
1950 Chevy 1/2 ton (original)
1941 Chevy coupe
1938 Chevy coupe streetrod
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1309023 Tue Apr 30 2019 11:06 AM
BigHog Offline
New distributor, new coil, and a new starter. She runs really well. Time to tackle gauges. My lights and signals and brake light all work, no gauges work, or wipers.
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1309133 Wed May 01 2019 02:24 AM
Mike B Offline
SLAWNSKI,
Looks good! Whats the back story to the color blue you used?
Mike B smile
Re: What did you get done on your bolt today???? [Re: BIG CHEVY 3600] #1309143 Wed May 01 2019 03:39 AM
JiMerit Boltr#43 Offline
Spare tire back where it belongs, think I need an X-RAY!
1946 1/2-Ton Chevy
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.7.3
