The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Points to Ponder
LOVE STRUCK!
You might be a Stovebolt Lover
Check the New Stuff and Announcements Forum
What do you think?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
4 registered members (ApacheFiend, JRMunn, coilover, windyville1), 360 guests, and 2 spiders.
Forums48
Topics117,321
Posts938,089
Members42,899
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 2 1 2
Re: One plug not firing [Re: neilroy] #471823 Sat Nov 15 2008 10:28 PM
Wrenchbender Ret. Offline
First find out wether you have spark to that cyl. or not. If not check the point gap. like TRK says sometimes a dist shaft is worn or bent enough that if the points are gapped too close one cyl will be the first to missfire. If you havn't replaced the cap it can be a hairline carbon track it it that may be very hard to find or may not show up at all.
1956 Chevy 1/2-Ton Pickup
Re: One plug not firing [Re: neilroy] #471899 Sun Nov 16 2008 02:49 AM
7
71DuallyFB Offline OP
I'm going to go by the local flea mkt tomm and see if I can find a deal on a gauge if not will check local parts stores for price..I guess it would be good to take a spare plug with me so I can get the right threads? anybody know what the ballpark reading should be?
anyway did the arc test tonite after it got dark...couldn't see any errant sparks and did the screwdriver test for fire...the plug wire does in fact have spark...must be a valve or compression issue...bummer...
anybody have any idea what a full valve job should run $$ wise as opposed to having an engine re-build kit put in? seems like if there's a stuck or burned valve on an eng this old I can't see the others being in great shape...
TIA
Mike
Re: One plug not firing [Re: 71DuallyFB] #471900 Sun Nov 16 2008 02:51 AM
47chevy6400 Offline
i have a small block 400 that had a broken rocker.
Re: One plug not firing [Re: neilroy] #472033 Sun Nov 16 2008 01:21 PM
excellant_62 Offline
could be the dist cap. That one contact may not be making contact. You should be able to pull that wire a little bit with it running and hear it arching. Worth a shot.
Re: One plug not firing [Re: excellant_62] #472390 Tue Nov 18 2008 03:50 AM
10 micron Offline
take a extra plug, put it on the end of #7 plug wire,ground plug and check for spark. if no spark you have bad/broken plug wire. you can also ohm out plug wire (check for resitance)
Re: One plug not firing [Re: 10 micron] #472456 Tue Nov 18 2008 05:15 AM
7
thanks guys...I did the spark test and it appears there is fire...I tried to get a compression gauge yesterday at the flea mkt but the only one I could find was pretty old and ate up looking..prolly wouldn't work...
I think the next thing I may try is pulling the valve cover and seeing if I can see the rockers moving as they should...if they are I would think maybe burnt valve(s)?
any other suggestions well appreciated...
thanks
Mike
Page 2 of 2 1 2
Moderated by  Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.7.3
