The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
10 registered members (3B, Gooberdog, drdoug, bartender, Johnny Rib, bwilliams), 301 guests, and 3 spiders.
Forums47
Topics116,112
Posts923,265
Members42,338
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 2 1 2
Battery Relay #463644 Tue Oct 21 2008 06:16 PM
4D6 Offline OP
Apprentice
My kids like to play in my '46 1/2 ton.. The way it is wired now though the starter is hot all the time. if you step on the starter it turns over, even with no key.. I found a 200A relay at:
http://www.wiringproducts.com/index1.html
I'm thinking I'll fuse a wire to the ignition and let the ignition connect the battery.
Anybody ever actually done this?
Experience is the ability to recognize a mistake when you make it again....
Re: Battery Relay [Re: 4D6] #463649 Tue Oct 21 2008 06:42 PM
Leon Offline
I've not done it, but I don't see why it wouldn't work.
A simple battery shutoff switch would be cheaper, though.
regards,
Leon
Re: Battery Relay [Re: 4D6] #463650 Tue Oct 21 2008 06:42 PM
atomarc Offline
4D6,
I haven't done this but I have a few thoughts on it. A 6 volt starter can pull 200 amps when it's really working hard. The other concern would be that the relay, if it's electrically held in, would have to have a duty cycle that allows you to drive for extended periods of time with it energized.
Your method of energizing the relay would have to be wired directly from the battery or the battery side of the relay for it to operate, it would be powered all the time.
Have you thought about one of those twist type battery disconnect switches mounted somewhere convenient?
I think this has been discussed here before and the problem was finding a solenoid (relay) that could handle being energized for hours at a time, as you drove around. Most were made for momentary service. There were some for maintained service (I think) but they were quite expensive. Good luck.
Stuart
Re: Battery Relay [Re: atomarc] #463653 Tue Oct 21 2008 06:46 PM
waldo53 Offline
Yeah, I like the battery disconnect better than a relay too. It also protects against little curious hands pulling on your light switch and running the battery down, or honking the horn to death.
Re: Battery Relay [Re: waldo53] #463657 Tue Oct 21 2008 06:56 PM
Leon Offline
The relay wouldn't have to power the whole truck, just the starter. You would move the system feed wire from the starter to the battery side of the relay. That way the relay only controls power for the starter.
That said, I am also a proponent of the battery shutoff switch.
regards,
Leon
Re: Battery Relay [Re: Leon] #463661 Tue Oct 21 2008 07:29 PM
atomarc Offline
Leon,
On a AD truck or a Deco truck, that connection on the starter switch that the BATT connects to IS power for the entire truck. Did I misunderstand your post?
Re: Battery Relay [Re: Leon] #463669 Tue Oct 21 2008 07:51 PM
4D6 Offline OP
Apprentice
That is a great idea. The rest of the system is switched by the ignition so why waste relay on other stuff.. I plan to give it a try, I'll ley y'all know how it goes in a few hundred starts..
Re: Battery Relay [Re: 4D6] #463670 Tue Oct 21 2008 08:25 PM
Leon Offline
atomarc,
you're right, my bad.
The way I was thinking would require another switch to control the relay so that it could be turned on when the starter was needed, and then turned off to keep the relay coil from overheating. I didn't think it through hard enough.
You could probably use a lever-type brake light switch actuated by the starter linkage to operate the relay.
Or, I wonder if the R-200A relay is actually rated for continuous duty? That's the concern that started all this.
Their #67015 is, but it only handles 85 amps.
regards,
Leon
Re: Battery Relay [Re: Leon] #463716 Tue Oct 21 2008 11:23 PM
Hotrod Lincoln Offline
Boltergeist
Just use a 6-volt Ford starter relay, and wire the energize lead to a hidden push button under the dash. When you push the button, the relay closes and puts battery power to the top terminal on the stomp starter switch. Those old relays were used through the 40's and 50's until 1955. There's one small terminal that is grounded by the starter button on the older ones. Newer models needed battery voltage from the "start" position of the ignition switch.
The murder victim was drowned in a bathtub full of Rice Krispies and milk.
The coroner blamed the crime on a cereal killer!
Re: Battery Relay [Re: Hotrod Lincoln] #463855 Wed Oct 22 2008 04:47 AM
carolines truck Offline
ya just learn something new everyday
Battery Terminal Solder Slugs
Battery terminal solder slugs were developed as a fast method for attaching a battery lug to a cable. A cost-efficient method that eliminates the need for and expensive crimping tool. Creates a rugged sealed connection for optimum performance. Slugs are color-coded for gauge size to industry standards. Select sizes from the drop down box.
How to use:
Strip cable so that the exposed copper reaches the battery terminal bottom
Apply several drops of flux to the exposed copper of the cable
Place the proper slug size into the battery terminal, and secure the battery terminal in a vice
Heat the base of the battery terminal with the slug inside using a propane torch or similar heat tool. As the battery terminal is heated, apply gentle downward pressure on the cable until the cable is inside the terminal. Remove heat source. Allow time for the connection to cool before handling
Always wear protective eyewear and clothing.
thanks 4D6
Jim & Caroline
The highway is for gamblers
Better use your good sense."
Gooday
that's my 1ยข answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Lucinda Otter-Purr our 51-3104 bolt
http://s67.photobucket.com/albums/h298/1951otter/?start=all
Inliner #4655
Every Shaver
Now Can Snore
Six More Minutes
Than Before ...
Half A Pound for
Half a Dollar
Spread On Thin
Above the Collar
BURMA-SHAVE
Page 1 of 2 1 2
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
