The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Happy New Year
2020
A New Year
A New Decade
A New Vision
Ring in the new with some quality time with your old truck! A great time to tackle a winter project. If you do not have access to your truck, start your parts list for spring!
The days are officially getting longer now, you know!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
17 registered members (Achipmunk, D B Cooper, Chico53, coilover, 1953 panel, 1 invisible), 382 guests, and 3 spiders.
Forums48
Topics117,051
Posts935,185
Members42,762
Most Online1,027
Dec 27th, 2019
Image Posting Policy
'54, 3100- 6 to 12 volt conversion #438097 Sat Aug 02 2008 02:46 PM
mr.brinker Offline OP
Apprentice
I am looking to convert from a 6 to a 12 volt system in my 1/2 ton truck. Is there a paticular alternator that would be more readily adaptable in regards to mounting and necessary output.
Thank you,
Fran
Re: '54, 3100- 6 to 12 volt conversion [Re: mr.brinker] #438109 Sat Aug 02 2008 04:35 PM
tclederman Online
Boltergeist
235 engine?
Standard equipment or additional 12v accessories?
New wiring harness; if yes, original-circuits or extra circuits?
Tim
1954Advance-Design.com
1954 3106 Carryall Suburban - part of the family for 49 years
1954 3104 5-window pickup w/Hydra-Matic - part of the family for 15 years
Z-series (54/55) GMC 350 (2-ton) COE - now part of Dave's family
- If you have to stomp on your foot-pedal starter, either you, or your starter, or your engine, has a problem.
- The 216 and early 235 engine are not "splash oilers" - this is a splash oiler.
Re: '54, 3100- 6 to 12 volt conversion [Re: tclederman] #438159 Sat Aug 02 2008 08:26 PM
Wrenchbender Ret. Offline
A 63 amp off a GM from 73- 85. will work real good. If the wire outlets are in the wrong possition you will have to change the "clock" possition.
1956 Chevy 1/2-Ton Pickup
Re: '54, 3100- 6 to 12 volt conversion [Re: Wrenchbender Ret.] #438171 Sat Aug 02 2008 09:09 PM
Kennethw Offline
Fran, If your interested in keeping the original apperance and converting your generator and regulator to 12 volt that is possible as well. Also, if your needing extra amperage that is also an option on your original generator while doing the conversion to 12 volt. You can private message me for more info if your interested in something like that.
If you want to go with an alternator, the Delco 10si internally regulated built as a "one wire" set up is nice and clean with a minimal amount of wiring since there is just one wire to deal with. This can be done in 6 or 12 volt. I can help you out with that as well.
Ken
Re: '54, 3100- 6 to 12 volt conversion [Re: tclederman] #438252 Sun Aug 03 2008 04:15 AM
Apprentice
Thanks to all. yes, I will be replacing the wiring harness and will possibly add AC and maybe power windows in the distant future, so I plan on having additional circuits available for those upgrades. I am running the stock 235.
Fran
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
