The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (89sbr), 292 guests, and 0 spiders.
Forums47
Topics115,013
Posts912,553
Members42,079
Most Online940
Apr 5th, 2017
Image Posting Policy
Where to connect oil pressure gauge? #435883
Fri Jul 25 2008 10:03 PM
Jim A  Offline OP
Northern California
My 261 has two ports near the oil line that feeds the external oil filter. One is a 1/4" the other is a 1/2". I'm not sure if they are on a common gallery or different/ I would suspect that the 1/4" pot is the proper choice. Anyone KNOW for sure is intended for the oil pressure gauge?
Re: Where to connect oil pressure gauge? [Re: Jim A] #435939
Sat Jul 26 2008 01:37 AM
DrewP  Offline
Glassboro,NJ
You can tee off the 1/2" NPT fitting from the lower port that feeds your filter.You can mount a gauge next to the block if you want.The 1/4" hole is plugged on my 261.
Drew
Re: Where to connect oil pressure gauge? [Re: DrewP] #436011
Sat Jul 26 2008 05:55 AM
Racecarl  Offline
McCook, NE USA
The smaller port (1/8" NPT) is a port that drains to the sump. This port would only be used for the old bypass filter.
I connected my oil pressure gauge to a port near the front of the engine. Between the generator and the block is a 1/8" NPT plug that is common to the galley that feeds the main bearings.
Remember 9-11-01--God Bless the USA
JUSTICE, not REVENGE, will prevail
1951 Chevy 1/2-ton Pickup truck
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
