The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 registered members (agedhorse), 283 guests, and 3 spiders.
Forums47
Topics115,005
Posts912,449
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Month My 57 Chevy Truck Made #424959
Fri Jun 20 2008 04:07 AM
U
UnklRod  Offline OP
Santa Rosa, Ca
Anywayto tell what month my 1957 Chevy pick up was made?
Thanks!
Jon
1957 Chevy 1/2-Ton Truck
More pix
The coldest winter I ever saw was a summer I spent in San Francisco M. Twain
If at first you don't succeed...skydiving is not for you!
If you don't like my carbon foot print, stick it up your Prius!!
Re: Month My 57 Chevy Truck Made [Re: UnklRod] #424999
Fri Jun 20 2008 07:24 AM
jockbolter50  Offline
Scotland
Hi Jon, try clicking on Links, go to the restoration section and you will see advice on how to decipher your trucks VIN code.
I assume you have the info to hand?
Hope this helps
Jock. grin
More pix on Flickr .
Re: Month My 57 Chevy Truck Made [Re: jockbolter50] #425005
Fri Jun 20 2008 09:06 AM
U
UnklRod  Offline OP
Santa Rosa, Ca
Jock,
Thank you for the info. However, I am new to the group and I could not find any information under restorations. Can you give me a bit of help on this? Thanks! Jon
More pix
Re: Month My 57 Chevy Truck Made [Re: UnklRod] #425026
Fri Jun 20 2008 01:41 PM
Flxible  Offline
north of the 49th
no, you won't find the month, except if everything is original you might guess from the date codes on all the attached bits and pieces ... the sequence number part of the vin will indicate early/late in the model year, they started at 001001 at each plant, a real low number might be the beginning of production in '56, a real high number will be toward fall '57
and Jock actually meant in tech tips section
Re: Month My 57 Chevy Truck Made [Re: Flxible] #425140
Fri Jun 20 2008 10:04 PM
Scotland
Thanks for putting me right Bill! I guess I was still a bit fuzzy! I hadn't had my caffeine fix at the time I answered the posting! dang
I hope Bill's info put you right Jon!
Regards Jock wave
Re: Month My 57 Chevy Truck Made [Re: jockbolter50] #425261
Sat Jun 21 2008 06:53 AM
4ontheFloor  Offline
Forest Grove, OR
If you get the restoration pack from GM, sometimes they give you a list of what serial numbers were made by month in your plant. My '50 pack has this info, mine was made in December by the serial number.
Paint & Body Shop moderator
Re: Month My 57 Chevy Truck Made [Re: 4ontheFloor] #425272
Sat Jun 21 2008 08:07 AM
U
UnklRod  Offline OP
Santa Rosa, Ca
4ontheFloor,
Does GM also provide you where your truck was made? My VIN is 3A570114510
More pix
Re: Month My 57 Chevy Truck Made [Re: UnklRod] #425490
Sun Jun 22 2008 03:22 AM
LONGBOX55  Offline
DANVILLE IL
The 5th digit in your VIN is more likely an "O" not "0", which indicates it was assembled in Oakland, CA.
Bill Burmeister
Re: Month My 57 Chevy Truck Made [Re: LONGBOX55] #425532
Sun Jun 22 2008 05:13 AM
U
UnklRod  Offline OP
Santa Rosa, Ca
Bill,
I got this info below from Mike Boteler:
All serial numbers in 1956 started with 1001, but the end number is un-known. One easy way to hone in on an approximant month is to check components for there date code. If you still have the original radiator, engine, trans and rear they are all coded. The radiator is easy, it will have the month and year stamped right on the front of the tank. The month are listed alphabetically with A = Jan, B=Feb etc. They don't use "i" as it looks like a 1.
More pix
Re: Month My 57 Chevy Truck Made [Re: UnklRod] #425548
Sun Jun 22 2008 06:47 AM
Flxible  Offline
north of the 49th
Rod - as I said above, and the numbers actually started at 001001 - your truck being #114510 [the 113,509th truck made at Oakland] would make it pretty late in the model year, I'd guess you'd find date codes from mid-57 or after, the '58's would start Nov-Dec '57 ... my ref says there were 351,739 trucks of all sizes built in '57 at all plants, 198,538 under 6000GV
I've never noticed a date code on a TF rad [and I've owned 3 57's as well as my 58], they're all stamped "H-55" for Harrison model 55, which is the TF series, along with a Harrison part #
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
