The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
15 registered members (DANNY J, Achipmunk, Bob Giles, Chevron, 49 3100, 1 invisible), 314 guests, and 3 spiders.
Forums47
Topics115,010
Posts912,534
Members42,077
Most Online940
Apr 5th, 2017
Image Posting Policy
Rear brake lines on '51 3100 #395780
Mon Mar 31 2008 01:39 PM
Ol' Red  Offline OP
Claremore, Oklahoma
My first attempt at bleeding the brakes was not so successful, so I get to redo that. In doing so, I want to replace the brake line that runs along (parallel to) the rear axle.
There is a "junction block" that feeds this brake line. It accepts fittings that go on a 3/16" line (they take a 3/8" wrench), but the wheel cylinders accept larger fittings, ones which fit on a 1/4" brake line (they take a 7/16" wrench). Therefore, it is necessary to have a "union" which converts from a 3/16" line to a 1/4" line for each wheel.
These "unions" seems like built-in opportunities for leaks. Is this standard? Why would they engineer this into the system? Am I missing something? Is there a foolproof way to go from 3/16" to 1/4" line?
DJ
'51 Chevy 3104 1/2-ton 216 -- "6 cylinders, 6 volts!"
Down with sesquipedalianism!
Re: Rear brake lines on '51 3100 [Re: Ol' Red] #395787
Mon Mar 31 2008 02:06 PM
BIG CHEVY 3600  Offline
DALLAS/BLANCO TEXAS
Junctions and other fittings are not a problem if you tighten them enough. What kind of truck do you have?
Send pictures...
Jim
Big Chevy's Photobucket pix
Modern ‘science’: the wonder of a
pre-determined mind…
The ‘baseline belief’ of astronomy:
“Any day now, we’ll pick up a tiny,
coded signal from outer space. Then
we’ll know for certain that there is
intelligence out there, because coded
information does not arise by chance”
The ‘baseline belief’ of biology:
The precisely coded genetic information in
every cell would fill many books…
but we know for certain that no intelligence
could have created life.”
Re: Rear brake lines on '51 3100 [Re: BIG CHEVY 3600] #395803
Mon Mar 31 2008 02:43 PM
U
Unsafe6  Offline
Apprentice
BC
Isnt There a 90deg. brass block with a banjo bolt and copper washers on each wheel cyl.? Mabey you have the wrong W/Cs.
I suffer from ADAD (Advance Design Acquisition Disorder)
Re: Rear brake lines on '51 3100 [Re: Unsafe6] #396127
Tue Apr 01 2008 03:41 AM
Achipmunk  Online
Boiling Springs, S. C. 29316
What Unsafe6 said.....
Pictures in my Photobucket
52 Chevy Panel
Re: Rear brake lines on '51 3100 [Re: Achipmunk] #396150
Tue Apr 01 2008 04:40 AM
Ol' Red  Offline OP
Claremore, Oklahoma
Hmmmm....I don't know what a banjo bolt is, so I Googled it, and it looks like a bleeder screw (a hollow shaft with a hole that can be exposed by unscrewing it slightly). My W/Cs have bleeder screws, but the threaded fitting that connects the brake line to the W/C is not a banjo bolt, I would say. And there's definitely no "90 degree brass block" on my W/C. I will take pictures and post, as BigChevy suggests. It will be Wed or Thur before I can get to it, though. Thanks for your help!!
DJ
Moderated by  53moneypit, Woogeroo
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
