The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
WELCOME
The site has expanded to include the 1973 to 1987 trucks!
Check out the new forum just for them and welcome our newest brothers and sisters with the "Rounded Line" trucks.
Encourage one another! Share what you've learned!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 members (CATMAN, BruceC, dougs, delky, DennisM, 1 invisible), 166 guests, and 3 robots.
Forums58
Topics121,784
Posts981,732
Members44,304
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 1 of 4 1 2 3 4
Excessive moisture ...
#39343 Wed Dec 15 2004 09:35 AM
mugsy Offline OP
...out of your tail pipe could be caused by a leaky head gasket or...?
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Re: Excessive moisture ...
#39344 Wed Dec 15 2004 01:40 PM
Mugsy: Could be, here in the midwest we have a lot of condesation, heat to cold back to starting it up and blowing droplets out the back of tail pipe. Easiest way to tell is everyday check radiator, with a marked stick, before start and see if its going down. Ben
popcorn The Truth is Out There (Good luck)
#39346 Thu Dec 16 2004 02:36 AM
You can smell a head gasket leak, especially if it smokes out the tailpipe. It would have a sweet smell to it. It's probably condensation burning out of the exhaust system until it's full hot,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
The red one [stovebolt.com] and The snow pusher [stovebolt.com]
1 1950 3100
1 1955.1 Chevy 6500 [stovebolt.com]
1 1954 Chevy 6500 2-Ton [stovebolt.com]
1 1955 1st Series COE 5700 [stovebolt.com]
1 1963 K20 [stovebolt.com] (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck [stovebolt.com]
1953 and a 1956 Ford F800 [stovebolt.com]
#39347 Thu Dec 16 2004 02:46 AM
If all your driving is city driving for short periods your muffler could be full of water. Get it out on the road for an hour or two and see if that helps.
My TRUCKS website
#39348 Thu Dec 16 2004 02:50 AM
mugsy Offline OP
Well, it's official. I got a leaky head gasket. Inspected things today and noticed brown stains running down the forward side cover. Then noticed some green coolant on the dizzy cap closest to head. It's been cold here the last month so I thought maybe that's where the condensation was coming from.
Yesterday, while driving, she was runnin' a little hot. Checked the coolant and it was low. Filled it up.
Checked again today and it's already a little lower.
So, if I'm lucky, I'll just have to change the head gasket. And if I'm not lucky? Thoughts?
-David
My \'65 Chevy C-20
#39349 Thu Dec 16 2004 03:04 AM
You might try re-torquing the head before tearing into it. One caution though. don't rev it up too much until you have it under control. I had a nasty head leak on my Morgan once while on vacation. White smoke out the back and all. Anyway punched it and it caused too much pressure in the cooling system. Puked the radiator and heater.
Dennis
40 Chevy 1/2 ton
#39350 Thu Dec 16 2004 03:05 AM
V
Before you rip it into millions of small bits , remove and inspect the spark plugs as water in the combustion chamber will make the plug squeaky clean .
-Nate
There is no problem so difficult it cannot be overcome by generous application of brute force & ignorance
#39351 Thu Dec 16 2004 06:19 AM
mugsy Offline OP
Is a head gasket just something that goes bad over time like a valve cover gasket? Or is it most likely an affect of an underlying problem such as clogged water passages?
I put a new radiator in last December and haven't had overheating problems since then. It ran a little hot a couple days ago but, the coolant was low.
No water evident in oil. The exhaust smells like exhaust. I'll check plugs tomorrow.
My \'65 Chevy C-20
#39352 Thu Dec 16 2004 07:17 AM
You can put oatmeal down the radiator cap
#39353 Thu Dec 16 2004 07:40 AM
mugsy Offline OP
Hey and it'll cook and be ready for a snack by the time I get to work. I like cinnamon and raisin best. Although the raisins might get hung up here and there.
My \'65 Chevy C-20
Page 1 of 4 1 2 3 4
Moderated by  Woogeroo
