Major event in Virginia
ODSS Bolters
return from
WINCHESTER
Virginia
September 21-23
Rolling in Winchester VA Read the
HOT WASH!
Searching the Site
16 members (Frank50, dgrinnan, D'Ecosse, Dragsix, Forty9, Danielbolt, 2 invisible), 398 guests, and 4 robots.
The Zone
Forums65
Topics123,412
Posts999,062
Members47,256
Most Online1,229
Jan 21st, 2020
jk55boy Offline OP
Apprentice
Could I use 1/4 inch stainless tubing for all my brake lines on my truck? Any info on this would be greatly appreciated.
Wanabe Mechanic
Jim
Modern ‘science’: the wonder of a
pre-determined mind…
The ‘baseline belief’ of astronomy:
“Any day now, we’ll pick up a tiny,
coded signal from outer space. Then
we’ll know for certain that there is
intelligence out there, because coded
information does not arise by chance”
The ‘baseline belief’ of biology:
The precisely coded genetic information in
every cell would fill many books…
but we know for certain that no intelligence
could have created life.”
This was covered not to long ago in another thread, but this is what we have determined. !/2 ton short bed uses 3/16" for all lines, 1/2 ton long and up uses 1/4" for all lines exept for the rear axle line, which is 3/16". It would be best to use the correct size for the truck.
Bill Burmeister
jk55boy
What are you working on? Are you going to upgrade brakes? Will you be using a booster MC? If so then the original size line requirement goes out the window.
Jim
As mentioned earlier there are standard sizes for various models but the important thing is to match the brake line size with the components on the truck. If you are going to use the original rear wheel cylinders and they have 3/16 fittings it wouldn't make any sense to try to adapt 1/4 lines. If you are using a later rear end and it uses a different size line, you will need to change accordingly.
Fred
jk55boy Offline OP
Apprentice
I plan on either using a 12 bolt rear end or a camaro rear end if I am able to find one reasonable. On the front I am puting mustang 2 stock size disc brakes. I have the power brake setup that fits in the stock location with a 7" booster. The reason I want to find a camaro rear end is because I am getting my front rotors with 5 on 4 and 3/4 bolt pattern.I use 1/4 " tubing at work on pneumatic controls and was wondering how hard it would be to find fittings to adapt.I will need to find aflare tool also. thanks for all the info
Wanabe Mechanic
You can use 1/4" lines. I have a 10 bolt Camaro with 12 disc brakes and I am using 3/16 lines. http://good-times.webshots.com/photo/2540282850099708909YZvPCm
I use a Snap-on flaring tool but you can find them at Northern Tool or Harbor Crap freight.
BTW the 12 bolt you are talking about is a later Camaro/Firebird rear. The 10 or 12 will fit depending on what year truck you have.
Jim
