The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Stovebolt is pleased to support the Salvation Army!
We're doing fine but many around the World are not. Instead of making a contribution to us this holiday season, how about making your contribution to a great organization with a long history of helping people in need around the world?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
6 registered members (J Lucas, Dusty, David C., Ott3r, 2 invisible), 336 guests, and 4 spiders.
Forums48
Topics116,582
Posts930,693
Members42,658
Most Online940
Apr 5th, 2017
Image Posting Policy
Problem with 292 Altenator alinement #349544 Sun Dec 16 2007 11:07 PM
Bub's 66 Offline OP
My son and I are rebuilding a 1966 c10 w/a 292 3 spd. We have ran into a problem where the alt does not line up even with the other pulleys. This is a new alt from Napa. Were there different styles made for that year.
Re: Problem with 292 Altenator alinement [Re: Bub's 66] #349564 Mon Dec 17 2007 12:47 AM
Wrenchbender Ret. Offline
The alts. were the same mountings but the 292 has different brackets then a 250-230. The 63-73 were different from the 74 up. Also the pulleys are different. That is were your problem is. You need the pulley from the old alt. They are easy to change.
1956 Chevy 1/2-Ton Pickup
Re: Problem with 292 Altenator alinement [Re: Wrenchbender Ret.] #349714 Mon Dec 17 2007 07:50 AM
carolines truck Offline
i made a heavy duty offset bracket (3/8-1/2'') that i bolted to the engine block. this has two holes drilled and taped to hold the alt bracket. my 292 (as many others) has to have the alt moved forward or backward when using a standard V belt to line up w/ the 292 pulley.
Jim & Caroline
The highway is for gamblers
Better use your good sense."
Gooday
that's my 1ยข answer due to the lousy economy ~ cause I ain't got - no . mo . doe
Lucinda Otter-Purr our 51-3104 bolt
http://s67.photobucket.com/albums/h298/1951otter/?start=all
Inliner #4655
Every Shaver
Now Can Snore
Six More Minutes
Than Before ...
Half A Pound for
Half a Dollar
Spread On Thin
Above the Collar
BURMA-SHAVE
Moderated by  Rusty Rod
Powered by UBB.threads™ PHP Forum Software 7.7.3
