We are still asking:
What did you get done on your Bolt today ????
The question, initially posted May 23, 2005, was:
"Whatcha do on your Bolt this weekend?"
After 51,906,997 views, 7378 replies over 185 pages, this thread in General Truck Talk is a happening! And it's not just weekends anymore.
Now with pictures and No BOTS.
So ...
What did you get done on your Bolt today????
Oh Lord, I just gotta find it....
Forums60
Topics127,583
Posts1,032,707
Members45,812
Most Online1,229 Jan 21st, 2020
 bed mounting wood
OP
ok i have looked through old posts and through how to make a bed. i read somewhere ,someome had the correct dem. for the wood spacer blocks for the AD truck. but i cant find that posting. could someone please tell me the mesurments or lead me to where to find them? thanks
gotta love old trucks
 Re: bed mounting wood
2 1/4" square by 2 5/16" tall .
OP
53chev: Sometimes the frame is tweaked a bit and the block height needs to be adjusted. The rear sill bracket is 4 inches tall. Each of the other mounting points needs to be just high enough to make the tops of all the cross sills level with each other and the top of the rear sill wood mounting surface. Shave your blocks if necessary to get everything level. Also, check the splash apron clearance to the bed side as that is controlled by the mounting block height.
Mar-Ktech
Apprentice
I just attached my bed this weekend using the 2 5/16" tall blocks I purchased online. They did not raise the bed enough to clear the top of the shocks. I bought some Maple and cut new ones at 3". This will give me some trouble when I go to install the running boards which I don't own yet. I'll have to jump that bridge when I get to it. I noticed that some online companies sell mounting pads for each block as well as the rear sill. The site I bought from only sold pads for the rear sill so I cut some of my own. 51 chevy 3/4 ton Martin
