The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
7 members (Rusty Rod, klhansen, MNSmith, KDrown, rfs56trk, 1 invisible), 182 guests, and 2 robots.
Forums50
Topics120,945
Posts969,505
Members43,798
Most Online1,229
Jan 21st, 2020
Image Posting Policy
my power brakes stopped working,help!
#29763 Sat Nov 24 2001 03:44 AM
kool 65 Offline OP
My street truck rod 65 chevy , has a 350-350turbo, it has after market power assisted brakes, but they just stopped working last night, the brake fluid is fine but no power brakes, help!,thanks kool guy frown
Re: my power brakes stopped working,help!
#29764 Sat Nov 24 2001 04:43 AM
Do you have a vacuum leak?
Do you hear a leak when you step on the brakes?
I would guess the vacuum line to the manifold is either lose or has a hole in it,possibly the checkvalve at the connectionon the brakebooster.
The other posibility is there is a problem with the diaphragm in the brake booster.
#29765 Sun Nov 25 2001 07:05 AM
kool 65 Offline OP
Yes, YEs there is definitly a hissing sound when I step on the brakes, also, it appears as though the lights go dim and bright when the brakes are pressed and the rpm seems affected and goes up a couple of notches, I will check the hose and the valve thingy tomorrow, thanks, kool 65 frown frown frown
Moderated by  Woogeroo
