The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Helping out ...
EVENTS
Check in for status!
Jump over to the Events Forum, to post events -- new ones or the ones we have been enjoying for some time.
Encourage one another!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
1 members (nyute), 209 guests, and 3 robots.
Forums50
Topics120,034
Posts961,342
Members43,542
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Suggested brake fluid
#22358 Sun Feb 15 2004 03:55 PM
cmayna Offline OP
Getting ready to install my new brake system (new SS lines and cylinders). What is the suggested brake fluid? Whats the difference between Dot 3, 4 and 5?
Craig's '50 Chevy 3100 5 window
My truck
If I'm not working on my truck or VW camper, I'm fishing with the wife or smoking Salmon.
Re: Suggested brake fluid
#22359 Sun Feb 15 2004 04:26 PM
Junior Member
DOT3 (&4) are glycol-based, while DOT5 is silicone-based.
In theory, DOT5 is superior to anything else as it has a higher boiling point and doesn't attract moisture, but for the life of me I have never had luck with the stuff. It seems to hold air which leads to spongy brakes and your system has to be totally rid of the old fluid as the two aren't compatible.
Valvoline Synpower makes a DOT4 that I can recommend. I wasn't satisfied with the brake performance in my '51, so I flushed out the DOT5 and replaced it with the Synpower DOT4 and all my problems went away.
#22360 Sun Feb 15 2004 07:14 PM
If it's a daily driver, go with dot4. If it's only driven to church (I know how often most of us go) use dot5.
Fred
52 3600
69 C-10
#22361 Sun Feb 15 2004 08:31 PM
smile Because of the high quality of restoration you are doing to your truck, Craig, I highly recommend DOT 5 Silicone. If you use regular Dot 3 or 4, you will put all of your paint restoration work at risk. Dot 3 or 4 will destroy your paint work no matter how careful you try to be. Dot 5 Silicone will not phase your paint work and be your best choice for all the other reasons. The only thing about Dot 5 that I have found to be a problem is leakage. It is so thin and slick that if your are going to have a leak in your system, it will show up with Dot 5 Silicone. Since you are totally rebuilding your system, that may not be a problem for you. I would take that chance.
As far as bleeding the air pockets out of it - yes, it does take longer to do that, but you can get them out. Patcience is the key! I know you have patience by what I see you are doing to your truck!
I have had it in my 37 since 1980 and have enjoyed all of the positive aspects of Dot 5 Silicone.
One last comment - it is expensive with a quart going for about $30.00.
See Joe Fuchs' 1937 Chevrolet 1/2 Ton Pick Up on Facebook at The Top Of My Page. Go to: Joe Fuchs on Facebook
#22362 Wed Feb 18 2004 05:34 AM
Junior Member
If you are starting out with clean lines and cylinders, use Dot 5.
I use it in my '54 3100, works fine.
#22363 Wed Feb 18 2004 07:52 AM
For those with original (vintage) master cylinders, DOT3. The newer stuff can harm the older rubber seals and cause leaks.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
#22364 Wed Feb 18 2004 10:05 AM
I use DOT3 or DOT4. Dot 4 is more hydroscopic than Dot3 (attracts water easier) but has a higher boiling point. Both Dot3 and dot 4 have a significantly lower boiling point when they are saturated with water, and should be changed annually since the stovebolt system is an open system. A system with a more modern master cylinder with a bellows breather can handle changes every two years. I change my fluid every 3 times I adjust the Hucks. Always change fluid anytime you open the system. I change it by cracking the far bleeder and topping it off as it bleeds down, and then re-bleed all four corners until it runs clear. That gets 99% of the water and crud out.
Paint & Body Shop moderator
#22365 Wed Feb 18 2004 02:03 PM
rat Offline
When I rebuilt my brake system I used Dot 5 and had trbl with leaks. I flushed out the Dot 5 and replaced it with Dot 3 and had no trbl. with leaks since. smile
'52 Chevy 5 window, it ran when I parked it
'53 Chevy 5 window, running the streets with me.
'55 Massey-Ferguson, tearing up the dirt
'89 Harley FXSTS, suicide clutch
'92 Harley FLSTC, equal time with the '89
Moderated by  Woogeroo
