The Stovebolt Page Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Work those trucks!
Share what you're up to this summer!
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
14 registered members (68ironhead, Hotrod Lincoln, glenns towing, 55_2nd_Series, Jon G, darthintel), 302 guests, and 3 spiders.
Forums47
Topics115,008
Posts912,478
Members42,075
Most Online940
Apr 5th, 2017
Image Posting Policy
Page 1 of 3 1 2 3
15 inch 8 lug one piece wheels? #200788
Sat Feb 11 2006 11:46 PM
bolt54  Offline OP
Staten Island, NY
I have a 1954 Chevy 3600. It currently has the split rims on it, 15", 8-lug. Does anybody know if there are 15", 8-lug one piece wheels available for my truck?
bolt54
1954 Chevy 3600
Re: 15 inch 8 lug one piece wheels? #200789
Sun Feb 12 2006 01:35 AM
48bigtrucks  Offline
Center Point, Iowa
I've got a couple in the white spoke style, so I know there's something out there. The one piece rims take a different tire than the splits do,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
1 1950 3100
1 1955.1 Chevy 6500
1 1954 Chevy 6500 2-Ton
1 1955 1st Series COE 5700
1 1963 K20 (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck
1953 and a 1956 Ford F800
Re: 15 inch 8 lug one piece wheels? #200790
Sun Feb 12 2006 01:38 AM
coilover  Offline
Plano, Tx
Millions. All eight lug wheels have the same bolt pattern but some have differant size pilot(center) holes.
Evan
Re: 15 inch 8 lug one piece wheels? #200791
Sun Feb 12 2006 01:59 AM
truckernix  Offline
Bracebridge Ontario Canada
They were the same pattern until about 2000 and they all went metric. With the AD trucks, backset clearance is a big issue.
1951 1 Ton Completed
Re: 15 inch 8 lug one piece wheels? #200792
Sun Feb 12 2006 02:38 AM
bolt54  Offline OP
Staten Island, NY
So I guess that there is no specific wheel that you can use, it is all trial and error?
bolt54
1954 Chevy 3600
Re: 15 inch 8 lug one piece wheels? #200793
Sun Feb 12 2006 02:46 AM
JiMerit Boltr#43  Offline
Turlock, CA
I'm trying to find a wheel shop that can punch the center out of my 15" splits and stick in in a non split outer rim. I want the center to keep my stock caps. Anyone done this???
1946 1/2-Ton Chevy
Re: 15 inch 8 lug one piece wheels? #200794
Sun Feb 12 2006 02:50 AM
OldSub  Offline
Seattle, Washington
Quote
That sounds like something Stockton Wheel or someone like them might do. I'm planning to do something similar with some bigger wheels, but haven't collected the pieces yet.
Its true, I really don't do anything but browse the Internet looking for trouble...
Steve@OldSub.com . www.OldSub.com . www.MaxwellGarage.com . www.OldGasTowRigs.com
'55 1st GMC Suburban . '54 GMC 250 trailer puller project. '54 GMC 250 Hydra-Matic . '54 Chevy 3100 . '47 Chevy COE . and more...
Re: 15 inch 8 lug one piece wheels? #200795
Sun Feb 12 2006 04:37 AM
mugsy  Offline
Lockhart, TX
OldSub beat me to it. Yeah, Stockton Wheel. I researched this a few months ago. There's a bunch of ugly, retarded looking wheels in 15" for 8 lug at places like Summit. Stockton Wheel is about the only place that has a traditional stock steel wheel in varying sizes.
Are you not interested in 16 or 16.5? Those are plentiful in the boneyards.
I wanted a 15" so I could do some L78-15 wide whitewalls but, have since decided to do bias blackwalls in 16 or 16.5 because of 8 lug availability in this size.
Tradin' up dimes for nickels...
My \'65 Chevy C-20
Re: 15 inch 8 lug one piece wheels? #200796
Sun Feb 12 2006 05:29 AM
Jim Karras  Offline
Orange, California
I had this done on my truck . I had a place called The Wheel Smith do mine. However, shortly after I had them done, they closed up shop. They had been around for some time.
Stockton Wheel is one the most popular places. But I have heard both good and bad about them.
http://www.stocktonwheel.com/
You might try these guys. I haven't used them, but someone awhile back told me about them.
http://www.custombuiltsteelwheels.com/
Good luck!
Jim Karras
Orange, CA
'59 Chevy Apache 32 Stepside Pickup
E-mail: Jim@59apache.com
Internet: www.59apache.com
Re: 15 inch 8 lug one piece wheels? #200797
Sun Feb 12 2006 12:51 PM
truckernix  Offline
bolt54,
what you will probably find with replacement wheels is some difficulty finding ones that clear the front tie rod ends. For the earlier AD trucks, usually the backset cannot be larger than about 4 1/4". Backset is usually defined using the surface where the bead meets the rim but in this case you have to consider the extra 1/2" of lip that sticks out beyond that point. When you get the old centers mounted in the newer style rims, Stockton may only be able to do this within a very specific range of backset on the rim. This is because of the flare of the center piece. As they trim the diameter to fit the new rim, the effective backset changes. I have seen this mentioned on another site. I think the 15" split rim centers work out well but I don't know about the 17" splitters.
Page 1 of 3 1 2 3
Moderated by  Justhorsenround
Powered by UBB.threads™ PHP Forum Software 7.6.1.1
