The Stovebolt.com Forums Home | FAQ | Forum | Swap Meet | Gallery | Tech Tips | Events | Features | Search | Hoo-Ya Shop
Hello there ...
We have a request from "Harold46".
Curious?
Stovebolt Site Search
Old Truck Calendars
Months of truck photos!
Stovebolt Calendars
Check for details!
12 members (Hugh63c10, Conductacator, JoeR, DavidBraley, Cletus1950, 1 invisible), 160 guests, and 5 robots.
Forums60
Topics124,014
Posts1,000,872
Members44,813
Most Online1,229
Jan 21st, 2020
Image Posting Policy
Page 2 of 5 1 2 3 4 5
Re: New smog check
#177947 Wed Nov 17 2004 03:14 AM
Moderator - The Electrical Bay and Rocky Mountain Bolters
clean the EGR (if it's got one), put in a new cat and new oxygen sensor(s)... change the oil, oil filter and air filter too, that will usually get them to pass the smog test.... also, maybe put the idle at the max end of the spec..
make sure it is HOT when you take it to the smog dude.
Another quality post.
Real Trucks Rattle
Re: New smog check
#177948 Wed Nov 17 2004 03:27 AM
Tony M Offline OP
Did all that Rusty, though it has no EGR.
I priced a cat and it is $260 installed. Not so nice when you sell the car for $1,500
54 3100 with 235
62 flatbed dump C60 with 261
Re: New smog check
#177949 Wed Nov 17 2004 04:03 AM
Moderator, Passing Lane
pay off the inspector grin
Redryder
My Hotrod
I am fighting cancer and I am winning the fight
Pain is part of life; misery is an option.
Re: New smog check
#177950 Wed Nov 17 2004 04:18 AM
A universal converter is less than $100..........but you have to weld it in.
An "Exact-Fit" type (direct bolt-in, no mods) is $50-$75 more.
A new cat won't do much for NOX, does wonders if you have high HC's.......
Also, new cat's need to be "burned-in" about 50-100 miles before they work at peak efficiency (sp?).
Good Luck smile
*** GMC ***
Re: New smog check
#177951 Wed Nov 17 2004 04:27 AM
Take it to a mechanic and get it diagnosed,
Scott
Scott Ward
2 1948 1.5-ton Loadmasters
The red one [stovebolt.com] and The snow pusher [stovebolt.com]
1 1950 3100
1 1955.1 Chevy 6500 [stovebolt.com]
1 1954 Chevy 6500 2-Ton [stovebolt.com]
1 1955 1st Series COE 5700 [stovebolt.com]
1 1963 K20 [stovebolt.com] (454)
1 1964 C10 (350)
1 1951 1.5-ton Dump Truck [stovebolt.com]
1953 and a 1956 Ford F800 [stovebolt.com]
Re: New smog check
#177952 Wed Nov 17 2004 05:10 AM
Tony M Offline OP
I talked to my Honda mechanic and he will have to look at it Thursday. I just hope I won't lose this buyer. I am not going to spend that kinda money blind unless I know it will fix it.
He says NOX is hard to figure out because he doesn't have the same equipment they do.
54 3100 with 235
Re: New smog check
#177953 Wed Nov 17 2004 08:46 AM
Ah, even in the smog-Nazi counties here in Missouri you can get away with anything. My '77 Corvette has none of the factory emissions equipment and a very non-conforming exhaust, and it still passes the "treadmill" test without a problem. grin They can give a visual inspection (not supposed to pass without required equipment), but they only do it if you have repeated failures.
1954 GMC De Luxe COE
Re: New smog check
#177954 Wed Nov 17 2004 03:19 PM
You might as well fix it if you are wanting to sell it and be thru with it,,,
Redryder
My Hotrod
Re: New smog check
#177955 Wed Nov 17 2004 04:20 PM
Tony, could you cut a deal with the buyer to lower the selling price if he agrees to do the repairs at his expense? Or maybe you can't even sign off on the car before it passes. Another reason I left the Golden State. But those beaches are smoke free zones. Gotta love it!
Bruce
Old Toy: Ol' Betsy stock 59 Apache SB Stepside (Gone but not Forgotten)
New Toy: 1962 Impala SS Coupe
The Driver: 1990 Toyota truck
Re: New smog check
#177956 Wed Nov 17 2004 04:45 PM
Tony M Offline OP
This guy is smart. He made the passing of the smog a contingency of the sale. I had it up for sale without getting the smog first hoping someone would just buy it without asking.
54 3100 with 235
Moderated by  Justhorsenround
