Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
12 members (55shaker, 51Craig1Ton, Dltalfa, 2-Ton, EdPruss, Hanks custodian, 1 invisible), 700 guests, and 3 robots.
The Zone
Forums65
Topics123,434
Posts999,411
Members47,277
Most Online1,229
Jan 21st, 2020
#1510182 Sun Jul 23 2023 10:35 AM
29tons Offline OP
What is the correct oil for a 1951 COE steering box?
29tons #1510308 Mon Jul 24 2023 03:49 AM
Some people on here have used John Deere corn head grease in them. Does a good job of lubricating and won't leak out as readily as oil will if your seals are bad.
Rich
1947 Loadmaster [stovebolt.com]
1947 Chev. Loadmaster
1959 Chev. Viking 40
Genie: "I am the genie from a magic lamp and I have the power to grant you three wishes."
Me: "I want to be rich."
Genie: "OK, Rich, what's your second wish?"
29tons #1510913 Fri Jul 28 2023 03:44 PM
My 46 2 ton calls for gear lube, I have good seals on it but it leaks through the threads on the large threaded nut for the adjustment. The owners manual states you never have to change the gear oil but gives instructions to add. Maybe no one cared if it leaked back then!!
29tons #1518082 Tue Sep 19 2023 06:09 AM
I rebuilt the manual steering gearbox in my Pontiac, back in the early 1990s. Was told to use CV axle grease because it's kinda liquid yet thick and super EP, being designed to keep Rzeppa constant velocity joints alive. I think I put a pint of it in there, but that was passenger car size versus truck size. It worked, too. Buttery smooth steering for years after, and never leaked a drop.
29tons #1518184 Tue Sep 19 2023 04:30 PM
The service manual makes no differentiation between pickup and big bolt steering gears as far as lubrication. It says that added lubricant should be one that's fluid at low temperatures and will not "channel" and which will provide satisfactory lubricant under extreme summer conditions. it says: Steering gear lubricants are marketed by many oil companies and either "Multi-Purpose" or "Universal" gear lubricants are satisfactory to use.
Clear as mud, right? One of the members here drdoug had a supply of NGLI 00 grease he was offering for steering gears. Supposedly Cornhead grease is NGLI 0 so slightly more liquid thicker than 00.
[on edit] I just read that CV joint grease was typically NGLI 1 grade, so thicker than 0 or 00. General purpose grease that's most commonly available for grease guns is NGLI 2
Last edited by klhansen; Tue Sep 19 2023 04:35 PM. Reason: corrected thickness of cornhead grease
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
