Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
13 members (Forty9, 32vsnake, Hambone, Hotrod Lincoln, Bill Hanlon, 2 invisible), 734 guests, and 3 robots.
The Zone
Forums65
Topics123,434
Posts999,404
Members47,277
Most Online1,229
Jan 21st, 2020
Got a question about tool post grinders! I'm grinding a piece of 3" diameter thick wall steel tubing between centers in my lathe. Should the workpiece be turning the same direction as the grinding wheel, or opposite its rotation? Surface finish isn't as big a consideration as the need to maintain a more accurate diameter than I can get with a carbide tool bit- - - -I'm looking for +/- .0005 or so.
Thanks!
Jerry, According to this, they should both be turning the same direction, so that the grinding wheel is moving opposite the workpiece direction at the contact point.
I found this video www.youtube.com/watch?app=desktop&v=DQhYDOx8yDk [youtube.com] and took a screen shot of it.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Moderator
Kevin is right! The contact point should be running in opposite directions.
Don
"The Flag Pole"
In the Stovebolt Gallery [stovebolt.com]
'46 2-Ton grain truck
'50 2-ton flatbed
'54 Pontiac Straight Eight
1954 Plymouth Belvidere
'70 American LaFrance pumper fire truck.
1976 Triumph TR-6
AD Addict
I agree with both Kevin and Don. If they weren’t running in the same direction (both clockwise or counter clockwise) the speed of the wheel would be effectively be reduced.
Phil
1952 Chevrolet 3100
Project Journals
Stovebolt Gallery Forum
‘59 235 w/hydraulic lifters
“Three on the Tree” & 4:11 torque tube
Updated to: 12v w/alternator, HEI & PCV
Moderated by  MNSmith
