Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
11 members (baldeagle, Burrell, 2-Ton, Jon G, 2 invisible), 82 guests, and 3 robots.
The Zone
Forums65
Topics123,447
Posts999,568
Members47,279
Most Online1,229
Jan 21st, 2020
#1516457 Fri Sep 08 2023 03:25 PM
TUTS 59 Offline OP
Crusty Old Sarge
I have a rolling chassis from a 1950 3100 project. The Steering column and gear are gone already, and the running board mounts have been cut off. It has a complete torque tube rear. I am willing to part it out or let it go complete. PM me for details, Thanks.
1950 3100 Chassis 1
1950 3100 Chassis 2
Craig
"Living life in the SLOW lane"
Come, Bleed or Blister something has got to give!!!
'58 Viking 4400, 235, 4 Speed (Thor)
I'm tinkering with an idea to build a modernized version of a doodlebug tractor. That frame might just be the last piece of the puzzle, since I've got the rest of the bits and pieces stockpiled already- - - -a Mercruiser 4 cylinder engine, a Turbo 350 automatic trans, a crash box 4 speed, and a 2 speed vacuum shift rear axle.
TUTS 59 Offline OP
Crusty Old Sarge
Jerry, if you can live without the rear crossmember it can be yours. I promised the crossmember to another "BOLTER".
Craig
TUTS 59 Offline OP
Crusty Old Sarge
The rear crossmember is spoken for.
Rear Crossmember 1
Rear Crossmember 2
Craig
No problem- - - -I will be bobbing the frame off and eliminating the rear springs anyway. Doodlebug tractors are as short-coupled as possible- - - - virtually no driveshaft, and minimal if any suspension. The front axle mounts on a center pivot in a home-brewed crossmember.
TUTS 59 Offline OP
Crusty Old Sarge
So your just wanting the bare frame? If so the rest of the suspension could still be available for parts for other Bolters. Let me know .
Craig
Sounds good- - - -I've got multiple bits and pieces of suspension, springs, steering components, etc. If someone closer to you needs a complete frame, I'll bow out- - - -got a 51 GMC long bed frame I had forgotten about decorating the barn lot!
