Fixing the old truck
BUSY BOLTERS
Are you one?
Not a hanging chad... The Shop Area
Searching the Site
14 members (2ManyTrucks, greenie-reddy, glennj3, 3B, breezy, Hotrod Lincoln, 1 invisible), 715 guests, and 3 robots.
The Zone
Forums65
Topics123,433
Posts999,394
Members47,277
Most Online1,229
Jan 21st, 2020
Page 3 of 4 1 2 3 4
“Grease Monkey” “Former herder of cats”
Judicial use of a 2lb hammer around the drum and a like amount of prying with a large screwdriver and a large amount of patience will usually be successful. Good luck.
‘65 Chevy Biscayne 4dr 230 I-6 one owner (I’m #2) “Emily”
‘39 Dodge Businessmans Coupe “Clarence”
"I fought the law and the law won" now I are a retired one!
Roger that
Haven’t gotten the adjusters to release so I’ll try pull the drum
Don’t see where I can get anything in to pry between drum and backing plate
Plate wraps around drum pretty well
How bad of an idea is it to loosen nuts on axle shaft tube so they cover the end of the tube to protect it and put a plate to cover the tube to have something to push against and use a harmonic balancer puller to pull on the flange where the axle shaft bolts to?
What am I missing
If I mess up the drum are they available
Got it
Found a purchase point
Lots of prying and beating
Didn’t swear once
Any suggestions to get brake return spring off/on
Pretty stiff spring
Was there a tool for this and don’t say vise grips
Vice grips wink
Do you have a brake spring tool? A plier like affair with items on the ends of the handles that help remove and install springs.
Newest Project - 51 Chevy 3100 work truck. Photos [flickr.com]
#2 - '29 Ford pickup restored from the ground up.
First car '29 Ford Special Coupe
Gearhead, Moderator for The Swap Meet and General Truck Talk
Jack,
Check out the picture in Figure 36 on Page 5-17 [chevy.oldcarmanualproject.com] of the Shop Manual.
Those nifty "brake spring removal pliers" can be found just about anywhere, even your local Harbor Freight [harborfreight.com], if you have one.
Dan
EDIT: Kevin beat me to the punch. thumbs_up
Dan
1951 Chevy 3 window 3100 (My Grandpa's hunting truck)
1966 Chevelle (Wife's Hot Rod)
2013 Chevy Silverado (Current daily driver)
US Army MSG Retired (1977-1998)
Com Fac Maint Lead Tech Retired (1998-2021)
Finally time to get to work on my Grandpa's (now mine) truck!
Thank you!
Update
Even with strong hands couldn’t get spring off with spring tool
I’m sure there’s a better set out there with more leverage
Put a vice grip on the hook of spring and used my huge channel lock to squeeze vice grip towards shoe face
Popped right off
Jack,
As has been said somewhere along the way, there is more than one way to get a job done.
Congrats on getting the spring off! wink
On to the next steps, yes?
Dan
Dan
Page 3 of 4 1 2 3 4
Moderated by  Dusty53
